Electrical problem ..please help!!! - Chevelle Tech
  • 1 Post By Jim Streib
post #1 of 8 (permalink) Old Apr 21st, 16, 10:29 PM Thread Starter
Rich
So I've been messing with hack wiring today. Got a new engine harness and managed to get power to ignition, distributor and starter. When I Turn the key one click (which would normally power the ignition and dash but no starter) the starter engages along with the distributor. Instead of when you turn the Key a full turn... Short story the starter stays engaged unless I kill power to car. Any ideas as to what I got wired wrong.
I have a basic understanding of electric but I really need help with this.
1972 ,non ss ,sbs ,th350
Any help is greatly appreciated.
Thanks rich
Rich5 is offline
post #2 of 8 (permalink) Old Apr 21st, 16, 11:24 PM
Re: Electrical problem ..please help!!!
Chances are you have the small wires backwards on the starter solenoid.
Disconnect the battery, remove the small wires on the small studs of the starter solenoid, then position them so they don't touch anything, then reconnect the battery and see which one shows power only when the key is in the crank position and this would go to the "S" terminal small stud on the starter solenoid and then the other goes to the "I" terminals small stud on the starter solenoid.
You can use a test light for checking things or a volt meter.
Dean likes this.
Always working on something:
Jim Streib is online now
post #3 of 8 (permalink) Old Apr 22nd, 16, 5:12 PM
Blake
Make sure the neither of the two smaller wire ring terminals are touching the larger BAT+ terminal. I notice that these two terminals are way too close to main battery terminal.
Basically you're getting current through your starter field windings through the main starter battery source at contacts/coil causing the prime mover to turn.
Also, red facing towards passenger fender, purple twoards driver fender.
blackbird307 is offline
post #4 of 8 (permalink) Old Apr 22nd, 16, 5:48 PM
While the below are for a 6 cylinder starter on my 68 Chevy II, the purple wire which should only have power when the key is in the crank position is closest to the motor and the ignition 12 volt output is the yellow farthest away from the block. I have to think 6 and V8 solenoids are the same in layout.
Also on my original solenoid, the small stud on the right for the purple wire has the S (for solenoid) and the other is marked R (for resistance wire).
Hope this helps.
post #5 of 8 (permalink) Old Apr 23rd, 16, 12:37 AM Thread Starter
Rich
Thanks guys, I'm going to work on the car tomorrow. I'll let you know how I made out!
Rich5 is offline
post #6 of 8 (permalink) Old Apr 23rd, 16, 2:26 PM Thread Starter
Rich
Looks like that was my problem. New starters on the way
Rich5 is offline
post #7 of 8 (permalink) Old Apr 23rd, 16, 2:30 PM Thread Starter
Rich
My solenoid s Missing a post
Rich5 is offline
post #8 of 8 (permalink) Old Apr 23rd, 16, 3:23 PM
Yep, you have both the wires to the "S" stud on the solenoid.
Since we don't know what you have for an ignition system and how it is getting power, post back with that info. The reason for this is you might be removing the one wire attached to the solenoid now with the other small wire and then either abandoning this one wire or you may have to put in a diode on the one wire.
Another option is see if just the solenoid can be swapped for the one with the two small studs on it and then those two small wires can go to the correct studs on the new solenoid.
This Thread is more than 1401 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
