missing part of horn wiring - Chevelle Tech
post #1 of 6 (permalink) Old Apr 16th, 16, 10:06 PM Thread Starter
Lynn
68 El Camino. Purchased it with an aftermarket wheel, but original was in bed.
When the original was removed, apparently the PO did not know he could remove the little brass contact and just snipped the black and white wires. The missing contact and little plastic retainer are mia.
Anyone know of a source for those parts? I can splice them in. The spring is still in the horn contact. Just need the brass contact and the plastic retainer.
LynnB is offline
post #2 of 6 (permalink) Old Apr 18th, 16, 10:19 PM Thread Starter
Lynn
Re: missing part of horn wiring
Don't know if those little pieces are reproduced, but I couldn't find them.
I made a piece out of a yellow wire butt connector. Cut it in half and crimped two pieces of wire in it. It was a little too wide to fit in the horn contact, so I filed it down leaving a little lip on each side to grab. Installed and connected the two wires to the clipped wires on my horn shroud.
LynnB is offline
post #3 of 6 (permalink) Old Apr 19th, 16, 4:38 AM
Have you tried the "Help" aisle at your local parts store?
SSJohn is online now
post #4 of 6 (permalink) Old Apr 19th, 16, 10:20 AM
let me look around tonight. I may have one that you can have if it didn't get tossed in spring cleaning over the years.
1949 Ford F-1, M-II IFS, 302 ford, C4, 9", tilt steering
1969 Malibu conv, LS1 w/magnuson SC, 4L60E
2004 Z06
04Z06vette is offline
post #5 of 6 (permalink) Old Apr 20th, 16, 8:15 AM
I was not able to locate one, but I did see similar things on line. Speedway, summit and steeringcolumnservices.com all list something that looks close. I think dorman also has a kit that may fit multiple years. it needs to be trimmed to fit.
2004 Z06
post #6 of 6 (permalink) Old Apr 24th, 16, 4:19 PM Thread Starter
Lynn
Thanks for the responses. I got it handled. Just made what I needed.
LynnB is offline
This Thread is more than 1127 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
