69 Elco wipers come on then off at random. - Chevelle Tech
post #1 of 3 (permalink) Old Mar 20th, 16, 4:22 PM Thread Starter
I have a weird issue with the wipers on my 69 El Camino... Every now and then the wipers will start then quickly retract.. I cleaned the switch, ran a new ground wire to the switch and cleaned the ground tab at the motor.. I also sprayed the contactor in the motor with CRC..
Thank you,
hydro462 is offline
post #2 of 3 (permalink) Old Mar 20th, 16, 5:33 PM
Hank
Re: 69 Elco wipers come on then off at random.
You may have the very rare option of intermittent wipers.
HKalin is online now
post #3 of 3 (permalink) Old Apr 3rd, 16, 10:44 PM Thread Starter
The problem was the little spring that keeps the contactor arm closed... I used an old distributor advance spring, no more haunted wipers...
hydro462 is offline
This Thread is more than 1519 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
