Appliance or Wiring?? - Chevelle Tech
post #1 of 6 (permalink) Old Mar 16th, 16, 7:34 AM Thread Starter
Hi guys, I renovated my home a month ago. As part of the renovation, I upgraded all the electrical wiring by the same contractors. But very often I'm not able to work well with my oven and iron box. Is this a problem with the appliance or wiring?
Dards1975 is offline
post #2 of 6 (permalink) Old Mar 16th, 16, 8:25 AM
wiring appliance breaker fuse electrical panel
Are you having tripped breakers at the electrical panel?
dogsridewith is offline
post #3 of 6 (permalink) Old Mar 16th, 16, 9:35 PM
dan
Re: Appliance or Wiring??
I would contact the electrical contractor that was involved in the renovation.
Dan5798 is offline
post #4 of 6 (permalink) Old Mar 16th, 16, 9:52 PM
BTK
billy the kid..
do the renovators have an electrical license ??? did the electrical inspector sign off on all of the up grades ??? was there an inspection at all ???...you don't want to find out by fire !!!!!
BTK is offline
post #5 of 6 (permalink) Old Mar 16th, 16, 9:57 PM
What is an iron box?
Sounds like they need to be on separate home runs if the breaker is tripping.
Did they get an electrical permit and inspection?
post #6 of 6 (permalink) Old Mar 17th, 16, 1:46 AM
The problem may be with both the wiring and appliances. Since both these appliances need more power supply, the wiring can also be a reason. What difficulty do you experience?? Any shocks or sparks?? I would suggest you to get it checked by an efficient electrician so that he can make out and rectify the problem it then and there itself.
Glarprive1992 is offline
This Thread is more than 1542 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
