Charging issue - Chevelle Tech
post #1 of 16 (permalink) Old Mar 11th, 16, 10:26 AM Thread Starter
Jon
Charging issue
I have a strange charging issues that I can't seem to figure out on my chevelle. I have all new parts and the battery is dying. I pulled the alternator, externally regulated and had it tested at the local auto zone. The alternator tested bad so I bought a new one and installed it, but still not charging correctly. So I picked up a VR715 voltage regulator and swapped that out hoping to fix my problem, but still not charging. I double checked to make sure the belts are tight and they are fine. What could I be missing?
1972 Chevelle SS 454 "W" code
JChilders is offline
post #2 of 16 (permalink) Old Mar 11th, 16, 10:59 AM
Re: Charging issue
Is there 12v to the exciter or field wire(s) ? what I am getting at is, is the car and battery "telling" the alternator that it is running and needs the alternator to start charging? I don't have a wiring diagram handy to speak from, but it seems like the Alternator is not getting "turned on " that or, the power it IS making is not getting to the battery
You should hear it " singing" when it is charging
What you do today dictates how fast you go Tomorrow
JFS65 is offline
post #3 of 16 (permalink) Old Mar 11th, 16, 11:26 AM Thread Starter
Jon
Re: Charging issue
I didn't think the test the voltage at the exciter wire. I know there is a blue and a white one, but I will need to figure out which is which. The car is pretty loud so I am not sure If I will be able to hear it over the motor, but I will check again tonight.
post #4 of 16 (permalink) Old Mar 11th, 16, 12:42 PM
Re: Charging issue
Make sure the voltage regulator is grounded well. When the alternator is charging it creates a magnetic field. You can stick a wrench to the back bearing from the magnetic field to quickly know if it is charging. Just be careful to not short out the battery connetion stud wire!
69SS454 is offline
post #5 of 16 (permalink) Old Mar 11th, 16, 1:39 PM
Rob
Re: Charging issue
I'd be interested in knowing the actual charge voltage at the alternator. It should be around 14.3 volts.
If the output is in the correct range than it's possible that the battery will not take a charge and it should be load tested to confirm if it's good or not. Once a battery goes below 11.8 volts a few times they usually will not come back from that no matter how much you charge them.
My build thread>
65chevelle300post is offline
post #6 of 16 (permalink) Old Mar 11th, 16, 1:46 PM Thread Starter
Jon
Re: Charging issue
The battery holds a good charge when I take it off of the battery charger. When the car is running the voltage is around 12.
post #7 of 16 (permalink) Old Mar 11th, 16, 2:32 PM
Rob
Re: Charging issue
Yes 12 volts isn't going to cut it. Is the Gen light coming on?
In order to find out if the alternator is working try unplugging the connector at the voltage regulator. Then connect a volt meter across the battery and start the engine. Jump the 3 to the F at the voltage regulator, this will make the alternator charge at maximum output. Only do this only for 5 seconds. You should be seeing 15+ volts on the meter if the alternator is good.
Also be sure and check the connectors going to the voltage regulator, they must be clean brass not corroded. You can usually clean them up if they are corroded.
My build thread>
post #8 of 16 (permalink) Old Mar 27th, 16, 11:37 PM Thread Starter
Jon
Re: Charging issue
OK so this is driving me crazy. I tried jumping out the wires at teh voltage regulator as described above and still nothing. The wiring harness is brand new from AAW so I am not ruling out a problem there, but I am hoping maybe I am missing something. I know I received an email about the gen lights, but I have a gauge car and do not have the idiot lights. Anyone have any other ideas?
post #9 of 16 (permalink) Old Mar 28th, 16, 1:03 AM
Levon
Re: Charging issue
Had one where the blue and white were wired incorrectly at the alternator. Blue should be outboard to the pass side, white inboard. Check them at the regulator as well. Should be brown, orange, white then blue from the top down.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #10 of 16 (permalink) Old Apr 4th, 16, 3:49 PM Thread Starter
Jon
Re: Charging issue
I checked all of the wiring and still no luck. I am thinking maybe I should try a one wire alternator and see if that fixes it. The wiring on this thing seems fairly simple so I am sure I am missing something stupid.
post #11 of 16 (permalink) Old Apr 5th, 16, 10:10 AM
Levon
Re: Charging issue
Jon, have a read through here. It may reveal a clue on your charging system.
Another question as well. Has the charging system ever worked or was it working then quit?
https://www.chevelles.com/forums/27-e...tor-works.html
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #12 of 16 (permalink) Old Apr 5th, 16, 11:09 AM Thread Starter
Jon
Re: Charging issue
Levon it is a frame off restoration and everything in new or rebuilt, but it has not worked since I got it all together. I will read through your article today and hopefully figure it out. Thanks!
post #13 of 16 (permalink) Old Apr 5th, 16, 11:15 AM
Levon
Re: Charging issue
Jon, I've seen this behavior before on frame off's. Folks over paint/coat things which can cause the grounds to not be intact. Try doing a ground connection from the alternator to the battery and from the regulator to battery.
Make sure they are clean and solid.
Often it is at the fender where the ground is applied AND the alternator mounts are too coated to provide a ground path to the block.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #14 of 16 (permalink) Old Apr 5th, 16, 11:30 AM
Re: Charging issue
This might help, or confuse more depending. Lots of good reading under the "electrical tech" section.
MadElectrical.com - Mad Enterprises
_______________
1970 SS/396 5 speed
Johnnyfixit is offline
post #15 of 16 (permalink) Old Apr 10th, 16, 4:29 PM Thread Starter
Jon
Re: Charging issue
Problem solved. Thanks everyone. Levon I did your step by step instructions and found my problem very quickly. The connector from the headlight harness and the engine harness was not completely connected. A quick squeeze until it clipped and my problems were solved.
This Thread is more than 1510 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
