Wiper Motor Ground Plate - Chevelle Tech
post #1 of 15 (permalink) Old Mar 8th, 16, 11:09 AM Thread Starter
Andrew
Ok, I replaced my wiper motor, switch and checked wiring ( new wiring harness). And my wipers still don't work on my 1970 Chevelle. I have tried to look for pics of how the wiper motor ground plate mounts but have found nothing! I read this is why my wipers are not working. Does anyone know how this ground plate should mount? Or do I even have the right plate for my motor? Here are some pics....
Thank you in advance!
ID:	338874   Click image for larger version
LooneyToons is offline
post #2 of 15 (permalink) Old Mar 8th, 16, 12:30 PM
Rob
Re: Wiper Motor Ground Plate
You need to ground the switch. The wiper motor has power all the time and the various functions are controlled by the switch grounding each function accordingly so if the switch isn't grounded nothing on the wiper motor will work.
The switch typically uses a ground strap for this such as the one shown in your picture where the wiper motor has one that is usually shorter attached to the lower bolt on the wiper motor although I'm not completely sure with your particular year.
My build thread>
65chevelle300post is offline
post #3 of 15 (permalink) Old Mar 8th, 16, 1:59 PM Thread Starter
Andrew
Thanks Rob! I currently have the switch grounded. Here is a picture of the switch. Perhaps the paint on switch needs to be scraped off for the ground strap/wire???
Name:	Wiper Switch.jpg
post #4 of 15 (permalink) Old Mar 8th, 16, 2:14 PM
Isn't that the wrong motor for a 70? Shouldn't it be the round motor?
69SS454 is online now
post #5 of 15 (permalink) Old Mar 8th, 16, 2:27 PM Thread Starter
Andrew
Bill, its the correct one (I think). Mounts perfectly and is exact to what was there before. Bought off of OPGI for correct year ( 1970), non-recessed,etc... I would feel real stupid if it was the wrong one! But wouldn't be the first time! Ha.....
It might look weird because I do not have the washer canister attached or the canister housing ( ?)...
post #6 of 15 (permalink) Old Mar 8th, 16, 2:52 PM
Ok, I see the square one is for non-consealed wipers and the round is for consealed. I don't think I know what a non-consealed wiper setup looks like on 69-72. Don't all of them conseal behind the hood?
post #7 of 15 (permalink) Old Mar 8th, 16, 4:59 PM Thread Starter
Andrew
I think they all are recessed to a point. I'm frustrated because I have already spent big money on the wipers, to the tune of about $450 ( $200/motor, $50/switch,$100 transmission arm, $100 wipers). Now I am hell bent on getting them to work! I would rather try to figure it out myself than take it to a shop and spend more money! Sigh.... I was hoping the wiper motor ground plate was the only missing part.
post #8 of 15 (permalink) Old Mar 8th, 16, 6:47 PM
Hank
To use the brass ground strap you are showing you have to remove one of the rubber mount steel bushings. Now sandwich the big end of the brass strap between the rubber and steel bushing and remount it. The smaller end with the hole should bolt to the wiper metal body somewhere. My motor is one of the round ones so I don't know exactly where the small end should bolt to on your plate. They make a shorter brass ground strap also but you could alter that one if you need to. The rubber bushings are for vibration the brass strap gets it ground to the firewall by the mounting screw going thru the steel bushing. After everything else you replaced I would have bought a new rubber mounting kit too.
1964-1972 Chevelle Wiper Motor Mounting Kit w/o Hidden Wipers
HKalin is online now
post #9 of 15 (permalink) Old Mar 8th, 16, 7:24 PM
First off, I hope this car ISN'T a Malibu or SS vehicle.
Typically stripped down cars got the non-depressed park wiper motors (Base model Chevelle, 300 Deluxe etc.). The upscale trim package Malibu or Super Sport in '70 automatically got the depressed park wiper system.
The depressed park units have a round cylinder like motor.
The switches are different between depressed park and non-depressed park as far as their functionality go. They aren't interchangeable. Also different transmission equipment connecting to the arms and the different base trim at the bottom of the windshield.
If your car is mechanically set-up correctly for non-depressed park, check your wiring functionality and switch operation via my guide:
https://www.chevelles.com/forums/27-e...r-systems.html
Coppertop is offline
post #10 of 15 (permalink) Old Mar 8th, 16, 10:39 PM
Read this thread, it may help.
"SSuper Dave" Palmer
A.C.E.S. #1483 TC #32 Gold
SSuper Dave is offline
post #11 of 15 (permalink) Old Mar 9th, 16, 11:23 AM Thread Starter
Andrew
Hank, I get how the big end should mount. But for the small end, when you say "wiper metal body", you mean "wiper motor metal body", correct? Just wanted to clarify...Thank you..
post #12 of 15 (permalink) Old Mar 9th, 16, 11:24 AM Thread Starter
Andrew
Joe, thanks for info and link! I am not sure what trim or model I have. I have the original Bill of Sale at home and will take a look when I get home. But I know it came with a 307.
post #13 of 15 (permalink) Old Mar 9th, 16, 5:13 PM
Hank
My car was a 307 Malibu but I'm sure you could have got that motor in a cheaper Chevelle model. The small end of the brass strap should mount to the wiper plate or motor what ever you want to call it. Your wiper motor is not grounded until that strap is connected to it.
post #14 of 15 (permalink) Old Mar 9th, 16, 11:06 PM
Steamy
Wink Re: Wiper Motor Ground Plate
Round motor, but same principle. Large hole end goes over the grommet sleeve that mounts the motor to the firewall, small end goes to the wiper transmission cover bolt.
BillL
My Showroom
Ark68SS is offline
post #15 of 15 (permalink) Old Mar 10th, 16, 10:56 AM Thread Starter
Andrew
Joe, my model number is 13437. So, from my basic search I have found I have the base or basic model. So, recessed wipers would not be included in my original package... please advise if I am wrong.... thanks!
1970 Chevelle RestoMod SBC 400
This Thread is more than 1580 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
