Gas Gauge - Chevelle Tech
post #1 of 6 (permalink) Old Mar 6th, 16, 3:09 PM Thread Starter
TKG
Terry
Gas Gauge
When I got my car (64) there was a box in the trunk, it had a box with pieces and parts of 3 SS dash panels. I know that the tank sender is different between a 64 and a 65, 30 ohm vs 90 ohm. Is there a simple test to see if the gauge itself is for a 30 or 90 ohm sender?
TKG is offline
post #2 of 6 (permalink) Old Mar 6th, 16, 3:47 PM
Levon
Re: Gas Gauge
Put an ohm meter on the sender pin and ground. Sweep the float and it should show 0-30 or 0-90 depending on what it is.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #3 of 6 (permalink) Old Mar 6th, 16, 7:08 PM Thread Starter
TKG
Terry
Re: Gas Gauge
Not the sender I know its a 30 ohm unit. I need to know how to check the gauge so that it matchs the sender.
TKG is offline
post #4 of 6 (permalink) Old Mar 6th, 16, 7:19 PM
Levon
Re: Gas Gauge
Maybe this will help:
The GM Fuel Gauge Mystery 1965 & Newer |
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #5 of 6 (permalink) Old Mar 6th, 16, 7:48 PM
Re: Gas Gauge
A lot of info there but not the answer. Do you have both sending units to just try them? I guess try the one you have and see how it works. You are not going to hurt anything by trying the wrong one. It just won't read right.
69SS454 is offline
post #6 of 6 (permalink) Old Mar 6th, 16, 8:11 PM
Levon
Re: Gas Gauge
Thanks Bill. You can do what Bill suggests. If you have a 12 V source for power at the rear of the car simply hook the sender to the gauges(and ground) and see what it reads.
If the gauges have part numbers, someone may have the data for them.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
This Thread is more than 1552 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
