Tempature lamp 69 El Camino.. - Chevelle Tech
post #1 of 3 (permalink) Old Mar 5th, 16, 4:35 PM Thread Starter
I just put my dash back together in my 69 El Camino.. I noticed the temp light doesn't light when the key is turned to either the on or start position..
Is it suppose to light while you are starting the car?
The oil pressure light comes on during start...
Thank you,
hydro462 is offline
post #2 of 3 (permalink) Old Mar 6th, 16, 10:44 AM
Re: Tempature lamp 69 El Camino..
The temperature dummy light should come on while you are cranking the engine. This was done as a self-test of the lamp.
The first thing to check is see if the lamp itself and related circuit is good....
Turn the key to "on", disconnect the wire from the temp sender on the engine, touch the wire's connector to a good ground--the dummy light should come on.
If it lights, there is an issue with the connection to the lamp test terminal on the ignition switch.
If it doesn't light, you have a bad bulb, poor socket connection or issue elsewhere in the circuit.
The bulb has +12v at all times when the key is on or cranking via the pink wire. The ground put on the dark green wire from the under hood sender OR the lamp test function of the ignition switch complete the circuit to make it light up.
Coppertop is offline
post #3 of 3 (permalink) Old Mar 6th, 16, 10:42 PM Thread Starter
Thanks Joe...
I grounded the terminal at the sensor and the lite comes on... The issue must be in the ignition switch...
hydro462 is offline
This Thread is more than 1545 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
