ss dash conversion - Page 2 - Chevelle Tech
post #16 of 18 (permalink) Old Mar 6th, 16, 3:07 PM
Re: ss dash conversion
Braided wire is not factory. Seems like a mess.
chopperb is offline
post #17 of 18 (permalink) Old Mar 6th, 16, 3:07 PM
Levon
The braided (cloth covered) wire is USUALLY the ignition resistance wire that goes to the + side of the coil. It is usually mated to a yellow one that goes to the R terminal at the starter. The cloth covered portion comes from the bulkhead at the firewall.
You may want to get this wiring diagram:
Classic Car Wiring . Com : Home of the original color laminated classic car wiring diagram for a 70 with gauges. Helps sort out a LOT.
There is also one available here (on line)
Documents - Peach State Chevelles
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #18 of 18 (permalink) Old Mar 6th, 16, 3:28 PM Thread Starter
Kevin
Ithink i will just replace the whole harness instead of trying to figure out the one that is on there. I see you can get the harness that has the hei plugs on it so nothing will be cobbed on. Thanks for your input, you have been very helpful in all of this.
hazel1 is offline
This Thread is more than 1542 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
