ground wire size ? - Chevelle Tech
  • 1 Post By onovakind67
post #1 of 2 (permalink) Old Feb 28th, 16, 7:19 PM Thread Starter
carlo
ground wire size ?
looking to upgrade some ground wires. would 6 gauge wire be to heavy ? ie. block to frame, dash to body. thanks.
hmardown
empty garage
hmardown is offline
post #2 of 2 (permalink) Old Feb 28th, 16, 7:45 PM
Re: ground wire size ?
It's tough to have too many grounds or to use too large a wire. Remember that the case of the alternator is the mother of all grounds, and if it is well attached to the engine block you can assume that they are at the same potential. Block to frame, block to dash, block to front sheet metal, etc.
VinceS427bb likes this.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
This Thread is more than 1492 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
