1971 Factory tach - how to check - Chevelle Tech
post #1 of 12 (permalink) Old Feb 25th, 16, 7:50 PM Thread Starter
I found a 71-2 factory tach to replace my 71 factory tach that doesn't work.How can I check the part that I'm buying is a working tach ? is there any way to bench test a factory tach ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #2 of 12 (permalink) Old Feb 25th, 16, 8:06 PM
RonO.
Re: 1971 Factory tach - how to check
Can't you just hook up a volt-ohm meter and measure the resistance? Measure the non-functional one and note resistance, then the new one. What's the difference in ohms?
1970 Chevelle 517 cid, TH400, best ET mid 9's. #19.
70SSTHUMPER is offline
post #3 of 12 (permalink) Old Feb 25th, 16, 8:48 PM
On a tach I have for my 74 Nova, I identified the connections then hooked it up to a power supply and a signal generator. The first part of the video's pictures are of the guts of the tach but later it shows connections to the power supply and signal generator.
I did this years ago and don't know what the settings were on the signal generator but it seems to me I used a square wave output and there was a relationship between the signal frequency and the reading of the tach as to RPM's being displayed.
Another option is to find a car with a points ignition and use some test wires off of the tach to the vehicles battery for power and ground and another wire for a signal from the coil. I would just do it carefully so nothing get's shorted and maybe put in a 5A inline fuse on the power line.
Always working on something:
Jim Streib is offline
post #4 of 12 (permalink) Old Feb 25th, 16, 11:01 PM Thread Starter
The non-functional one is still in the dashboard of my ElCamino and the one I am considering is still in its owners possession.
I should have made it clear I was looking for a quick way to check it before I bought it.How would I even do that or is it a crap shoot ? and hope for the best.
71 El Camino SS
71350SS is offline
post #5 of 12 (permalink) Old Feb 26th, 16, 1:40 AM
Would the seller be comfortable if both of you knew exactly how to wire it and then temporarily wired it up safely to a car under the hood using the cars battery for power and ground and then a connection to the ignition coils negative terminal ?.
You asked if there was a way to bench check it and this is the only way I can thing of without using any high tech tools like I did with a power supply and a signal generator. A meter is not going to tell you how well or poorly the needle will move as the only way to really test it is in a real life condition.
If all else fails, give it a sniff test and visual look. If it smells like burnt wiring or there is more than just a little surface rust you might pass on the deal BUT if we are only talking 5 bucks or less, then take a chance. If it's way above market value, and it's being sold as-is you might wait for something else.
post #6 of 12 (permalink) Old Feb 26th, 16, 11:52 PM Thread Starter
Thank you Jim.I'm well aware of how to hook up a tachometer but I doubt the seller would go for that unless he understands what my risks are.
What's a good price for a used factory tach ? Or would I just be better off removing my tach and sending it out for repair ?
71 El Camino SS
71350SS is offline
post #7 of 12 (permalink) Old Feb 27th, 16, 7:59 AM
No, that won't tell you much of anything. Tachometers are not as simple as a fuel or temperature gage and even then resistance measurements are not reliable.
On a tach I have for my 74 Nova, I identified the connections then hooked it up to a power supply and a signal generator. . . . . . . .
Jim is correct. I use a Signal/Function Generator and a 12V DC source also. I use a 30% duty cycle ground referenced 12V peak square wave for these checks. This is a snapshot of the functional test worksheet I use:
Name:	Tach Worksheet.JPG
USAF Retired (1968-1988)
David Bates is offline
post #8 of 12 (permalink) Old Feb 27th, 16, 10:15 PM
Weldon
You could hook the tach power wiring to a 12 volt source and then use a simple pushbutton switch to simulate the signal with 12 volts through the pushbutton to the siganl wire.
Just push the button rapidly and watch for movement of the needle.
Quick and dirty.
Weldon
64 El Camino
67 Mercury Cougar
66 Chrysler 300
2011 Harley Davidson TriGlide
Team Chevelle #5157
wihaltom is offline
post #9 of 12 (permalink) Old Feb 28th, 16, 7:50 AM
Quick and dirty.
Although this will yield some "twitching" of a functioning tachometer's needle, keep in mind you would have to press the button 33.33 times per second for a V8 tachometer to indicate 500 RPM which I don't think you would be able to do. Consequently you would still have no way of knowing whether it is linear or accurate.
post #10 of 12 (permalink) Old Feb 28th, 16, 8:11 AM
I just pop the hood of the car it is supposed to go on and connect it temporarily with clip leads to power, ground, and the coil. If it works, it works. If not, you aren't guessing anymore.
Gary S is offline
post #11 of 12 (permalink) Old Feb 28th, 16, 9:36 AM
Shane
Reproduction tachs are $159 on ebay.
Give him a "tested" offer, and an "untested" offer.
or ask him for a guarantee...
fishhead is offline
post #12 of 12 (permalink) Old Feb 28th, 16, 10:32 PM
Weldon
That is completely correct.
I just read his post as asking how to tell if the tach worked.
This quick little test would at least let him know if the device did function, with no accuracy or linearity implied.
You would need a very quick finger to get more than about 5 hertz with that little pushbutton!!
Weldon
64 El Camino
67 Mercury Cougar
66 Chrysler 300
Team Chevelle #5157
wihaltom is offline
This Thread is more than 1497 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
