voltage gauge jumping ? - Page 2 - Chevelle Tech
post #16 of 18 (permalink) Old Feb 26th, 16, 7:59 PM Thread Starter
carlo
Re: voltage gauge jumping ?
update:
I think I found my problem. I started by checking all my fuses & contacts in the bulk head. there were fuse in there since Nixon was in office. after changing, checking & cleaning everything I still had issues. I couldn't understand why I was hearing a clicking noise under the dash. I only noticed it because the car was not running & I turned the key in the on position. otherwise with the car running I would have never heard it. so this sent me under the dash looking for my flasher(#552). after removing the panel under the steering wheel I was able to find my flasher. all three wires leading to the flasher were pinched between the bracket & two bolts holding up the steering wheel. I mean they were crushed & I was the last one under there about a year ago. I usually check & double check chit like that but it happens. glad I didn't burn the harness up. I dropped the column & everything seems much better. I'll need to fix the three wires because they're toast. I did get to clean up a lot of ground wires & may consider installing relay's to my headlights. I want to thank everyone for jumping in with solutions & advice. so thanks, Rob, Tony, Bill, Dean, Ed, Gary, onovakind67, dogsridewith, & Geoff I appreciate the help.
hmardown
empty garage
hmardown is offline
post #17 of 18 (permalink) Old Feb 27th, 16, 3:02 AM
Glad you got it fixed. And yeah, you are lucky the harness didn't catch fire. A few years ago, a buddy of mine re wired his entire car with a PainlessWiring harness kit . The car was a beautiful 1965 Impala Super Sport. A wire became pinched between the dash structure and a bracket....the wire eventually caught fire and pretty much destroyed the car.
1.8TTony is offline
post #18 of 18 (permalink) Old Feb 27th, 16, 9:08 AM Thread Starter
carlo
those three wires are half way between the plug & where they come out of the harness(not much room to work). I couldn't believe how flat the wires got. there's also a couple of frayed wires on two of them. not sure if I'll cut & just shorten them. or maybe just splice an extension & put the flasher off to the side. some days you're windshield, some days you're the bug. thanks.
hmardown
empty garage
hmardown is offline
This Thread is more than 1457 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
