What is this contactor, and where/how do I get one? - Chevelle Tech
post #1 of 6 (permalink) Old Feb 25th, 16, 7:38 PM Thread Starter
Mark
I tried to change my turn signal switch today, and found these terminals bent and the plastic holder broken. I assume that they follow the turn signal contact points as it is activated. What do you call this assembly, and where/how do I get one?
Name:	IMG_2005 (800x600).jpg
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #2 of 6 (permalink) Old Feb 25th, 16, 8:18 PM
Hank
Re: What is this contactor, and where/how do I get one?
I think that may be for the key buzzer.
HKalin is offline
post #3 of 6 (permalink) Old Feb 25th, 16, 8:27 PM Thread Starter
Mark
Yes Hank, I think you're right. I think I can leave it out then. I hate those buzzers! Good thing it broke then!
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #4 of 6 (permalink) Old Feb 25th, 16, 8:33 PM
I'd still like to know where to find them. I have dozens for tilt wheel columns but, I could use a source for the non-tilt columns.
Toppless72 is offline
post #5 of 6 (permalink) Old Feb 25th, 16, 8:40 PM Thread Starter
Mark
Got $80?!?!?
1969-1976 Corvette w/Tele Key Warning Buzzer Switch
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #6 of 6 (permalink) Old Feb 25th, 16, 8:44 PM Thread Starter
Mark
This one is better: 1969 88 GM Cars Without Tilt Ignition Key Buzzer Switch GM 7804414 | eBay
I guess it is GM 7804414
Getting better $12.54 1993 Chevrolet Beretta Parts - GM Parts Online - GM Parts Direct
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
This Thread is more than 1462 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
