cooling fan temp sensor wiring question - Chevelle Tech
post #1 of 11 (permalink) Old Feb 25th, 16, 2:56 PM Thread Starter
I recently added aftermarket AC to my 67 El Camino. I thought installing an aux electric fan would be a good idea.
I am going to wire it through a standard Boch style relay and that is all pretty straight forward.
My question is the sensor that came with it, it has 2 prongs to wire to.
My experience has been with a single connection that when at the right temp provides a path to ground and completes the circuit.
I have been searching for any kind of diagram on how to wire the 2 connections. I connected my VOM on the continuity setting and connected to both connections, and carefully heated the probe end with a bic lighter very slowly (to not damage it) but it never completed the circuit.
The sensor has a part # KSD301-P but when I google that I find everything but that.
Am I correct in assuming that the 2 connections are the path to ground and wire it that way?
Thanks for any insight on this, because I am almost at the point of purchasing a sensor with only 1 connection if I cannot figure this one out.
Mick
El Camino - A Chevelle that hauls
Emptytank is offline
post #2 of 11 (permalink) Old Feb 25th, 16, 3:12 PM
Re: cooling fan temp sensor wiring question
Can you post a picture of the sensor. Is it long and thin? That may be a thermocouple not a switch. If it is, it needs to wire to a circuit board not directly to a relay.
69SS454 is offline
post #3 of 11 (permalink) Old Feb 25th, 16, 3:16 PM
If it is disk shaped, the two wires are probably the normally open or normally closed switch connections, neither going to ground.
69SS454 is offline
post #4 of 11 (permalink) Old Feb 25th, 16, 3:38 PM Thread Starter
Here is a pic of the sensor my fingers are covering up the small threaded post that screws into the brass piece, that is screwed into the bung on my water pump
Mick
post #5 of 11 (permalink) Old Feb 25th, 16, 3:47 PM
I would say that neither terminal makes a path to ground. 82 degrees C is 180 degrees F. It should either open or close a connection between the two terminals at 180 degrees.
69SS454 is offline
post #6 of 11 (permalink) Old Feb 25th, 16, 3:52 PM
gary
It probably would complete the circit between the terminals at 180*. But I would call the seller to verify.
post #7 of 11 (permalink) Old Feb 25th, 16, 4:18 PM Thread Starter
Thanks, I guess I was wording the question wrong, that at temp the 2 prongs complete a connection, so if the connection was to complete the path to ground if it went from one connection to the other.
The problem contacting the seller is that I bought this stuff last summer, and am now just getting around to installing it and could not find the paperwork that came with it. That is on me :-(
Mick
post #8 of 11 (permalink) Old Feb 25th, 16, 7:16 PM
gary
I would put the sensor in hot water above 180* & check for continuity between terminals & terminals to the base.
post #9 of 11 (permalink) Old Feb 26th, 16, 9:55 AM Thread Starter
That will be the next thing I am going to try. Hopefully that is it. I kind of tried that with the lighter, but I was worried about damaging it, I don' think water will.
Mick
post #10 of 11 (permalink) Old Mar 2nd, 16, 11:14 AM Thread Starter
Just a follow up, I did use the hot water test as suggested and discovered that at 180* there was continuity between the 2 connections, and as it cooled down I could actually feel the disconnect (kind of a click) but now I can wire this up correctly.
Thanks to all who pitched in with comments, and suggestions.
~ Mick
Mick
post #11 of 11 (permalink) Old Mar 2nd, 16, 9:49 PM
Sweet! Glad you are on your way.
69SS454 is offline
This Thread is more than 1326 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
