turn signal problems - Chevelle Tech
post #1 of 7 (permalink) Old Feb 25th, 16, 12:06 PM Thread Starter
Richard
Send a message via Yahoo to cookie
Question turn signal problems
My turn signals have stopped working1 However when I step on the brakes ,all four bulbs lite up.. I can't find out why?
cookie is offline
post #2 of 7 (permalink) Old Feb 25th, 16, 12:18 PM
Mark
Re: turn signal problems
You probably have a filament burnt on one of your tail lights and laying on the parking light filament causing the backfeed through the front lights.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #3 of 7 (permalink) Old Feb 25th, 16, 12:35 PM
Al
If a brake light /tail light bulb or lamp (as it may be called) is in the socket incorrectly it will give you a back feed and illuminate the dash lamps also.
Al
alhewitt is offline
post #4 of 7 (permalink) Old Feb 25th, 16, 1:38 PM
Step on the brakes and find the one bulb that is not doing the exact same thing that the others are doing. That one is the culprit.
69SS454 is offline
post #5 of 7 (permalink) Old Feb 25th, 16, 3:04 PM Thread Starter
Richard
I have changer all bulbs, but this has not fixed the problem yet!
cookie is offline
post #6 of 7 (permalink) Old Feb 25th, 16, 3:14 PM
Do your 4 way flashers work? If they do, you need to check the flasher unit located in a harness above the steering column where the column mounts to the dash. There is a clip that the unit fits into on the dash brace but, it's most likely just hanging by the two wires. The flasher unit in the corner of the fuse box is for the 4 way hazard flashers. As a test, just replace it with one from another vehicle. Report what you find.
Toppless72 is offline
post #7 of 7 (permalink) Old Feb 25th, 16, 9:38 PM Thread Starter
Richard
Thanks: for your help! I found the problem to be in the 4 way flasher switch. Some how it got stuck in the on position I got it free, changed the fuse, and everything is working again!
cookie is offline
This Thread is more than 1502 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
