Ignition wiring question on a 66 - Chevelle Tech
post #1 of 4 (permalink) Old Feb 18th, 16, 10:00 PM Thread Starter
Larry
I am reassembling my 66 with a 327 auto part of the harness that runs along the firewall just behind the distributor has three wires that stick out a blue one goes to the oil sensor and a reddish pink goes to the positive of the coil the last one is a black wire with a white fabric coating it appears to have been connected to the spade that connects to the positive coil terminal along with the reddish pink one It was cut and not connected prior to restoration I can start the car now without it connected Do I need it?
Organics08 is offline
post #2 of 4 (permalink) Old Feb 18th, 16, 10:12 PM
Levon
Re: Ignition wiring question on a 66
The pink and black/fabric goes to the + side of the coil. The pink is fed from the starter at the S terminal and the black is from the ballast resistor.
Starts on pink and runs on the black. Sound like your pink is also wired somewhere else though.
Here's a wiring diagram:
http://macc.chevelles.net/images/66w...gram_color.jpg
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is online now
post #3 of 4 (permalink) Old Feb 19th, 16, 10:29 AM
Banned
Cory
In an attempt to clarify-try and disregard the prvious post when reading the following:
The fabric coated wire is a resistor wire which reduces voltage to the coil from 12v to 9v and is the primary positive feed to the coil when the engine is running (key switch in the "ON" position).
The purple wire is routed to the starter solenoid which activates the starter when the key switch is in the "START" position. During this event, the solenoid acts as a relay to route 12v to the coil via the brown wire for starting events only.
YES, you need it connected if the remainder of the coil/solenoid connections are installed correctly. I suspect that they are not since your engine continues to run with key switch in the "ON" position...Meaning you are sending 12v to the coil at all times.
dream66 is offline
post #4 of 4 (permalink) Old Feb 19th, 16, 12:23 PM
Are you still running a points type distributor? The Black wire may have been removed because the car is using an electronic points replacement or an HEI and needed full batt+ to operate the ignition.
oldcutlass is offline
This Thread is more than 1465 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
