Tanks Inc, Fuel float issue. - Chevelle Tech
post #1 of 8 (permalink) Old Jan 8th, 16, 6:15 PM Thread Starter
James
Hey guys, recently bought a Tanks, Inc. fuel tank kit (with electric pump, fuel level sending unit) for my EFI project. The pump seems to run fine, however the fuel gauge sender seems to be acting funny. See if you can keep up...
When the float on the unit is physically at the 'Full' position, fuel gauge reads at "super full" (needle swings over on top of the 'Generator' light, all the way to the right, at 3 o'clock position)
When float is at 'Half full' position, fuel gauge reads "Full"
When float is at the 'Empty' position, fuel gauge reads back to "super full"
I've seen a few people have stated they need some adjustments, so I played around with the float rod length, having it extend out the opposite side instead, or maybe I had some wires crossed, installed the float resistor backwards/upside down, so I double checked everything, even though I hadn't changed anything other than the tank itself. Everything was installed the way the instructions said. Nothing up in the dash has been touched/changed. Grounds are all good, and it's just the one wire from the sending unit (other than ground wire). It's almost as if the floater resistor was designed sideways. I have not yet reached out to Tanks, Inc yet, as they don't seem to have a support email, and I'm not at the car until after work, of which then they are closed for the day. Do they have a Rep floating in the forums somewhere here?
I'll try digging around on here more for any more info, as well as Google, but figured someone on here probably has the same kit, possibly some advice/troubleshooting ideas. I have photos if anyone needs a visual.
Car is a '69 Chevelle, 307. Dashboard instruments are stock. Wiring harness is an American Autowire kit.
Cheers.
James
69307/350Chevelle is offline
post #2 of 8 (permalink) Old Jan 8th, 16, 10:14 PM
Chevelle Doctor
Re: Tanks Inc, Fuel float issue.
If you have a volt/ohm meter, measure the resistance of the sender at full, 1/2, and empty. Should be 90 ohms at full, proportionally down to 0 ohms at empty. Gauge past full is usually an open circuit, in this case, more than 90 ohms.
Authentication and pre-purchase inspection service still available. PM me for more information.
Still looking for that elusive 76 Nova SS.
People who have nothing better to do than b!tch about signatures need to get a life.
70 Chevelle L78/M21
10 Avalanche LT 1500 4wd
06 Equinox
Dave Birdwell is offline
post #3 of 8 (permalink) Old Jan 8th, 16, 10:55 PM
Troy
There are several different sending units available, are sure you have the correct one?
http://www.tanksinc.com/index.cfm/pa...rod/prd276.htm
senna is offline
post #4 of 8 (permalink) Old Jan 9th, 16, 12:23 AM
Mark
I used the TAN-GML 0-90 ohm, and my gauge reads great. The gauge is NVU 69 series gauges, though. It's a little odd to figure out the installation instructions, but I got it eventually.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is online now
post #5 of 8 (permalink) Old Jan 9th, 16, 1:34 AM Thread Starter
James
Clicked on your link. I nearly fell over in my chair. Checked my part numbers, they aren't the ones for " '65 and up".... Wow. Can't believe I made such rookie mistake and ordered the wrong part. However, when I added the tank to my shopping cart it suggested my current sender as an accessory. Oh well, always double check your stuff before you order. Live and learn. I'll update once I get the correct sender....
post #6 of 8 (permalink) Old Jan 9th, 16, 1:58 AM
Troy
Other than the sending unit, how do you like the tank?
This is the set up I plan on using for my LS swap. I really like the idea of an internal pump vs mounting an external pump. And the price point is very nice.
senna is offline
post #7 of 8 (permalink) Old Jan 9th, 16, 6:37 AM Thread Starter
James
The price for everything was nice. It all fits in the tank very nicely, and the directions are relatively easy to follow (even if you have the wrong sender). The only thing wrong that I've had trouble with is getting it to fit. I've got a '69 4 door, and perhaps the frame rails are narrower towards the back of the car over the coupes, but I've had to bend the side flange welding points down/up so it's narrower to fit in between the frame rails. I had the same problem with a replacement OEM tank a few years back, it was just too wide to fit. I don't think anyone with a coupe has had that problem. Other than that it's pretty nice so far and I haven't had any issues. The mounting straps were the same, and it comes with a vent tube.
post #8 of 8 (permalink) Old Jan 9th, 16, 12:18 PM
Troy
Thanks for the info!
senna is offline
This Thread is more than 1508 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
