wiring - Chevelle Tech
post #1 of 3 (permalink) Old Jan 6th, 16, 1:23 PM Thread Starter
wiring
can anyone tell me what the black wire in the connector , on the back of the fuel gauge ( with the huge wire end on it ) is? and where it connects to ? i didn't tare this car down, but im trying to wire the dash up using the original under dash harness., It is a 1969 chevelle , and i have no idea what it is, i assume ground but it seems to have a small amount of power in it...any help would be useful...thanks, Ed
dieseled3 is offline
post #2 of 3 (permalink) Old Jan 6th, 16, 2:55 PM
Re: wiring
I can check my old harness tonight, but according to the diagram I have, there are only 2 wires on the fuel gauge. a pink which was 12v from fuseblock which also went to temp, oil, alt and brake indicators and a yellow or tan wire which is the wire from the sending unit. the only large connector I remember is a big ring terminal about 1 inch diameter that connects to the housing of the cigarette lighter on the dash. that was a black wire.
04Z06vette is offline
post #3 of 3 (permalink) Old Jan 7th, 16, 2:18 PM Thread Starter
Re: wiring
hey thanks alot 04Z06vette , that is where it goes (back of lighter) i think 68 's only have two wires, this 69 has three and this wire is connected to the middle one (apparently ground), but after seeing your reply i looked closer and i could see a faded ring where it rubbed the lighter housing and thats it...thanks again
This Thread is more than 1355 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
