71/72 Sweep Dash Wiring Harness - Chevelle Tech
post #1 of 4 (permalink) Old Jan 5th, 16, 7:46 PM Thread Starter
Tim
I am sure I would have to fish through many posts; but, I am looking for a quick answer.
I have a 71' Heavy Chevy Chevelle with a sweep dash.
I recently had a small fire around the firewall inside and out and it affected some of the wiring on the inside.
My question is will a 72' sweep dash wiring harness for the inside gauge cluster work on the 71'?
I have read somewhere there are some differences; but, upon looking at the photos taken by the seller it seems the gas gauge adapter, lighter adapter, heater adapter, and so forth all appear to be the same as well as the adapter that goes to the rear of the car.
As always, any help is appreciated. Thanks, Tim.
Tim's_2nd_Chevelle is offline
post #2 of 4 (permalink) Old Jan 5th, 16, 7:49 PM
Re: 71/72 Sweep Dash Wiring Harness
It will NOT work. They are wired totally different. Find the correct year harness. The speedometer cluster will not know the difference, but the rest of the wiring in the car will. I may have the correct harness that you need. Private Message me if you are interested.
RealRed70 is offline
post #3 of 4 (permalink) Old Jan 5th, 16, 8:18 PM Thread Starter
Tim
Dan, tried to PM you but not sure it is working.
post #4 of 4 (permalink) Old Jan 5th, 16, 9:24 PM
It worked fine. I responded to it.
This Thread is more than 1508 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
