american autowire compatibility - Chevelle Tech
post #1 of 4 (permalink) Old Jan 5th, 16, 7:25 AM Thread Starter
Matt
Will the Ch85032 kit for 68 chevelle work in a 69?
matt_glesn is offline
post #2 of 4 (permalink) Old Jan 5th, 16, 7:31 AM
Bryan
Re: american autowire compatibility
Anything can be made to work---but this particular set will have an issue.
Since the 69 is a column mounted ignition switch and the 68 is dash mounted, the biggest issue that I could foresee is wire length---incorrect connectors to the switch.
I don't imagine that the rest of the kit would be all that much different than a correct kit for your car.
If you are not comfortable playing with wiring----probably be a good idea to get the right kit.
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done
On the street now!!!
Bryan59EC is offline
post #3 of 4 (permalink) Old Jan 5th, 16, 10:00 AM
Donny
No, they are extremely different. Not even close. Pin outs are a bit different, column vs. dash mounted ignition switch, etc.
Donny
aawtech is offline
post #4 of 4 (permalink) Old Jan 5th, 16, 10:47 AM Thread Starter
Matt
Ok thanks guys
This Thread is more than 1615 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
