Turning signals - Chevelle Tech
post #1 of 4 (permalink) Old Dec 28th, 15, 3:10 AM Thread Starter
Turning signals
Every light works perfectly fine but the turning signals when I use the hazards they work fine too for the front and back what could be the problem
d_montano22 is offline
post #2 of 4 (permalink) Old Dec 28th, 15, 6:01 AM
Bruce
Re: Turning signals
Have you checked the Turn Signal Flasher Pod? There are two Flashers, one for the Turn Signals, and another for the 4 ways. For a GM A Body of the Muscle Car era, the flasher is up under the dash, to the passenger side of the steering column.
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 4 (permalink) Old Dec 28th, 15, 8:38 AM
Re: Turning signals
Turn signals will not work when the hazards are flashing.
oldcutlass is offline
post #4 of 4 (permalink) Old Dec 28th, 15, 10:37 AM
Bryan
Re: Turning signals
Turn signal flasher may be bad----the older cars had this flasher mounted under the dash near the steering column-----the one on/near the fusebox is for the hazards.
Could also be a fuse but not knowing year of car can't tell which fuse it is
might be marked on the fusebox tho
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done
On the street now!!!
Bryan59EC is offline
This Thread is more than 1483 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
