No Spark coming to plugs - Chevelle Tech
post #1 of 12 (permalink) Old Dec 27th, 15, 12:12 PM Thread Starter
Richard
I just replaced my old bulky HEI with the MSD Pro-Billet distributor (p/n 8360) and blaster 2 coil. The engine ran fine with the old HEI but now there is no spark with the new system. I used the same ignition wire for the coil as before. I also made sure to note which plug the rotor was positioned at. There is power going to the coil when the key is turned on. Is it possible that I received a bad coil? Is there a way to check the coil. I have the orange wire to coil negative and the red one (and the ignition key wire) to coil positive. The black wire is to ground.
1969 Chevelle, Malibu, Convertible, Glacier Blue, 350ci #'s matching
Apollo 9 is offline
post #2 of 12 (permalink) Old Dec 28th, 15, 1:32 AM
Re: No Spark coming to plugs
system hickup!
SCOTT
SWHEATON is offline
post #3 of 12 (permalink) Old Dec 28th, 15, 1:33 AM
" I used the same ignition wire for the coil as before "
If its the stock wire from the original points setup thats approx 9v +- so the old elec ign was ok working with less then 12v which was ok.
But the new msd ign & or coil may need a full 12v to run .
Could also be an issue with wire from starter solenoid that sends 12v start only voltage to coil to get motor fired when ign sw is at its full travel position spinning the motor over the start.
Then when the motor starts & ign sw is released thats when the 9v is put thru the old points wire which the msd ign or coil can run on.
Call MSD techline & tell them how you hooked it up and the symptoms & they will get you squared away quicker real time on the phone then going back & forth here with mult post trying to get across to us whats going on.
SCOTT
SWHEATON is offline
post #4 of 12 (permalink) Old Dec 28th, 15, 8:53 AM
Have you checked to see if you have voltage at the coil while ignition key is in the start and crank positions?
oldcutlass is offline
post #5 of 12 (permalink) Old Dec 29th, 15, 11:09 PM Thread Starter
Richard
Thanks for the replies. I ended up moving the ground wire from the firewall directly to the engine and that solved the problem.
Apollo 9 is offline
post #6 of 12 (permalink) Old Dec 29th, 15, 11:36 PM
What ground wire? Is the ground strap that runs from your engine to the firewall installed?
post #7 of 12 (permalink) Old Dec 30th, 15, 11:35 PM Thread Starter
Richard
Yes there was no ground strap from the firewall to the engine. As a result, the firewall was not giving me a proper ground.
Apollo 9 is offline
post #8 of 12 (permalink) Old Dec 30th, 15, 11:50 PM
My suggestion is to install the missing ground strap as you will have other issues in the future.
post #9 of 12 (permalink) Old Dec 31st, 15, 12:27 AM
The body ground should be a short wire from the negative battery cable to the fender.
post #10 of 12 (permalink) Old Dec 31st, 15, 12:49 AM
There should be 3 braided straps.
https://www.chevelles.com/forums/showthread.php?t=426345
post #11 of 12 (permalink) Old Dec 31st, 15, 9:41 AM
Keep in mind that ground straps that connect to the motor by the valve cover bolts are only for radio noise suppression.
If you think about it, you can't torque down valve cover bolts tight enough for a good ground.
post #12 of 12 (permalink) Old Dec 31st, 15, 7:48 PM
ALWAYS, large gauge ground wire from negative BATTERY term, directly to engine. Our cars sometimes have an accessory small gauge ground from BATTERY to front sheet metal. then, added ground straps, engine to chassis/body.
As far as the Blaster 2 coils, they are notorious for being defective new, and/or causing ignition module failures for both MSD boxes, and HEI systems. Plug gap with one of those coils, NO MORE THAN .035.
Dave Ray is offline
This Thread is more than 1513 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
