No power from ignition posts help - Chevelle Tech
post #1 of 14 (permalink) Old Dec 27th, 15, 2:55 AM Thread Starter
I just changed engines, had a v8 pulled it, stuck another rebuilt one in, I have a hei distributer with the power to it coming from the fuse block "ign" post just as I had on the previous engine, except now I have no power!!??? I ran a wire directly from the battery to the distributer for engine (camshaft) break in and it ran fine. Did I miss something here? Can anyone help? Lights and all else seems ok...
66evlle is offline
post #2 of 14 (permalink) Old Dec 27th, 15, 8:15 AM
Re: No power from ignition posts help
https://www.chevelles.com/forums/arch.../t-127025.html
oldcutlass is offline
post #3 of 14 (permalink) Old Dec 27th, 15, 9:32 AM
I would go backwards,--- #1- Ign. ON, In run, Position--- Then check hot wire to HEI with test light. If the hot wire is OK, Then go to the Dist.
#2-- NO power to HEI hot wire, Continue to back up or start at the HEI-12 Vt. source.
Or be a dumb AZZ like me, I have a toggle switch on my 12Vt. HEI-Feed wire from the Fuse box. ( Kill HEI power is nice for cranking engine /or working on Elect, stuff). So my Sta. Wgn. will not start one day. I get grumpy and P!$$ed
After making an Azz of my self ,,,, I turn on the " Toggle Swtch ". Start engine and leave.
I kinda sorta felt the the back half of a Halloween Horse Costume !
Robinls5 is offline
post #4 of 14 (permalink) Old Dec 27th, 15, 10:14 AM
Rob
Might want to check out the neutral safety switch.
My build thread>
65chevelle300post is offline
post #5 of 14 (permalink) Old Dec 27th, 15, 10:20 AM
Neutral safety switch has nothing to do with power to the distributor.
Probably blew the fuse, either that or the fuse is not making good contact with one of its holder clips.
post #6 of 14 (permalink) Old Dec 27th, 15, 11:24 AM Thread Starter
Blew the fuse?? Where is that located?
66evlle is offline
post #7 of 14 (permalink) Old Dec 27th, 15, 11:52 AM
Rob
Here is what I read Dean.
I have a hei distributer with the power to it coming from the fuse block "ign" post just as I had on the previous engine"
Initial start up requires power from the starter.
My build thread>
post #8 of 14 (permalink) Old Dec 27th, 15, 12:00 PM Thread Starter
All I know is the initial power goes to the starter on the purple wire when you turn the key to start, after engine fires you are in the run position which requires 12v to the distributer, which I had on the wire from the tab on the fuse block labeled ign. Now I don't have power on that tab....
66evlle is offline
post #9 of 14 (permalink) Old Dec 27th, 15, 12:03 PM
Rob
Did you change out the resistor wire for the HEI? I was thinking no power meant it didn't even turn over. I see now where you had to hot wire the car for it to start, didn't read that correctly.
Those fuses can blow and still look good sometimes so when in doubt change the fuse.
My build thread>
post #10 of 14 (permalink) Old Dec 27th, 15, 12:15 PM Thread Starter
Once again where is this fuse located?
66evlle is offline
post #11 of 14 (permalink) Old Dec 27th, 15, 12:18 PM
Again, on a Chevelle that has the distributor's primary ignition power wire being fed from the "IGN" terminal on the fuse block, neither the starter or neutral safety switch has anything whatsoever to do with that power wire from the fuse block being dead.
He said the car starts with a jumper from the battery so obviously the starter is working.
Now IF for some reason the bypass wire was put back, the motor would start but die as soon as the key was released from the "start" position.
Check the fuses.
post #12 of 14 (permalink) Old Dec 27th, 15, 12:25 PM
I *think* it's the radio fuse but can't remember for sure.
check them all
post #13 of 14 (permalink) Old Dec 27th, 15, 1:18 PM
From the link provided above...
Do the turn signals/heater work? If not, I would check the fuse first. Should be the turn signal/heater fuse, which is right next to the IGN terminal. Anything connected to that terminal is protected by that fuse. With a meter or test light, check both sides of the fuse clip holders. If one side has power and the other doesn't its the fuse. If both sides don't have power, then it would probably be the IGN switch, although if it was, there would be other things not working either, radio, wipers, ect...
post #14 of 14 (permalink) Old Dec 27th, 15, 1:26 PM Thread Starter
Found blown fuse, it was the bottom one, car runs great now!!! Thanks to all for hep, sometimes it's just simple stuff when your mind is on your new engine!!!
66evlle is offline
This Thread is more than 1623 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
