starter solenoid - Chevelle Tech
post #1 of 12 (permalink) Old Dec 19th, 15, 11:13 AM Thread Starter
TONY
starter solenoid
i had someone suggest i put a ford starter solenoid to stop the starter from not working after the car was hot.I have already put a blanket on the starter.The car has shorty headders that have been ceramic coated.It is a big block car and will not happen when the car is cool.Has anyone done this and if so how is it wired
3karfan is offline
post #2 of 12 (permalink) Old Dec 19th, 15, 11:22 AM
Re: starter solenoid
I'd suggest replacing the starter, that's the problem. Had the same problem in my car last year with a starter that had been fine for many many years. Might look into one of the small late model permanent magnet starters, probably won't be as close to the headers. Worked out well for me.
72 Chevelle SS conv
72ragtop is offline
post #3 of 12 (permalink) Old Dec 19th, 15, 12:14 PM
I've never had to do it (YET) because I found out long long ago that headers are not worth all the trouble that they cause for the little horse power gain on a street driven car but here is one way that somebody posted.
post #4 of 12 (permalink) Old Dec 19th, 15, 12:54 PM
IF I was going to install the Ford type solenoid I think I would do it like this.
post #5 of 12 (permalink) Old Dec 19th, 15, 1:10 PM
Vince
no this would be better as in
i have done it and it looks like this;
i have electronic ignition also-the coil is powered by alternate wiring.
Name:	FordSolenoid wiring.JPG
the solenoid on the starter is energized by the battery cable when start is activated,
i have used it for years, no issues
VinceS427bb is offline
post #6 of 12 (permalink) Old Dec 19th, 15, 1:26 PM
I had starting issues with my 70 - 468. The old, GM starter was having a tought time doing its job. I bought a NEW Delco Starter with the one piece housing, 70 style ( short HI/Perf Solinoid) and the top thru bolt was designed (long enough)to attach the 70 starter brace.
The New Delco spins the 468 on a VERY HOT day & HOT engine, Like the plugs are out.
Good cables & wiring & starter..... You will be good to go.
When you are in your 70s ,,, You learn. " Good parts aint cheap & Cheap parts aint good "
P.S. this was 5-6 years and 34.000 miles ago. I had headers in the 70s / 80s, For a race car, Excellent. For a street machine, A Hellava lot of work & Pain for the end result. Do what is best for you.
Robinls5 is offline
post #7 of 12 (permalink) Old Dec 19th, 15, 1:36 PM
Rob
X2 this is correct. Starters that don't work when the engine is hot are bad. It's also likely that using a remote solenoid won't make any difference. Replace the starter with a high quality replacement like a high torque Power Master.
My build thread>
65chevelle300post is offline
post #8 of 12 (permalink) Old Dec 19th, 15, 4:42 PM Thread Starter
TONY
Thanks for all the input...i am currently running a powermaster 9100 chevy mini starter?The battery is also in the trunk.Iam using 1awg welding cable
3karfan is offline
post #9 of 12 (permalink) Old Dec 19th, 15, 5:23 PM
Danny
If you decide to go with the ford solenoid get the start-em up kit from mad industries comes with what you need and Mark knows his stuff. Put mine on in 1989 when engine was rebuilt and tight probably don't need it now but has been great and you can hide it if you want.
DJsSS is offline
post #10 of 12 (permalink) Old Dec 19th, 15, 6:23 PM
With the battery in the trunk and saying you are using 1awg welding cable, do you have a positive cable and a negative 1awg wire going between the battery and the engine ?. If you are running just a 1awg from the battery positive up to the starter and using short connections from the battery negative to the back of the car, do you have another connection between the front of the car and the engine block ?. The power has to make a loop and if there is a restriction in either the positive or negative path, the starter might not be getting what it needs.
Another thing to look at is with a rear mounted battery, where is the voltage sense wire on the alternator connected at ?. If the voltage sense wire is up front, then due to the voltage drops on the cabling back to the battery, you may have 14 volts up front but in back have less to where the battery might not be getting fully charged.
Another thing to look at is the connections on things like the 1awg cable. Sometimes crimped on connections are fine and last a long time but maybe solder the lugs onto the wire.
The powermaster 9100 installation manual also states that the starter is not designed for high compression motors. They also suggest using a 1awg when the main cable is 7' long. If it's closer to 10' then they suggest using a 1/0 cable.
Also, has it always been this way or has the issue slowly been become worse and worse ?.
Maybe the battery is weak ?.
Always working on something:
Jim Streib is online now
post #11 of 12 (permalink) Old Dec 19th, 15, 7:10 PM
Attachment 317801
Yep, that would work fine too.
There is no "I" terminal, it should be labeled "R" on a GM starter but I guess it doesn't matter since there is no wire on that terminal (if no points).
Actually, I personally believe that although it does work, installing the second solenoid is really fixing the symptom rather than fixing the cause which is usually not enough power to the "S" terminal under load caused by poor connections but it is a lot easier than fixing the cause.
IF the battery has be re-located, refer to post #10
post #12 of 12 (permalink) Old Dec 21st, 15, 5:26 PM
poor connections
Mmmmhhhhhhmmmmm.
That's been pretty much the totality of my experience with this "heat soak" stuff. That and properly sized wiring with soldered, heat shrunk connections. Takes lots of time but worth it.
charbilly2001 is offline
This Thread is more than 1689 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
