'68 Dash Bulb Sockets - Chevelle Tech
post #1 of 14 (permalink) Old Dec 16th, 15, 5:48 PM Thread Starter
Bruce
OK, got my next issue with the wiring in this '68 el Camino dash...
2 of the sockets that plug into the back of the dash are gone beyond repair. Checked on the internet and can't seem to find any correct ones? Anyone know where to buy them or have a few spare they could part with?
They are the plastic housing, single wire with metal ground that clips into the dash lamp holes, like the one pictured, need at least 2 good ones with 3"-4" of wire coming out the back.....
Name:	dash socket.JPG
'68 el Camino SS 396/325hp, 4 Speed, 3.31, Buckets, AC
'75 el Camino SS, 400 SB, 200R4, 3.42 LSD, AC, Swivel Buckets, PW, PDL
'87 el Camino SS 305 TPI, 200R4, 3.73 LSD
'87 Buick Grand National (Hardtop, Bucket Seats)
PaceCarNut is offline
post #2 of 14 (permalink) Old Dec 16th, 15, 5:50 PM
Re: '68 Dash Bulb Sockets
I think I may have some of those left over from another project. I'll check and get back to you.
63 Nova wagon
Philip is offline
post #3 of 14 (permalink) Old Dec 16th, 15, 6:04 PM
Found several but no wire or contact in them. The sockets are new if you can use them PM your address and I'll mail them to you.
63 Nova wagon
Philip is offline
post #4 of 14 (permalink) Old Dec 17th, 15, 12:16 PM
Steamy
I'm pretty sure that American Autowire carries replacement sockets.
BillL
My Showroom
Ark68SS is offline
post #5 of 14 (permalink) Old Dec 17th, 15, 1:12 PM
Rob
69 looks same.....see this thread. https://www.chevelles.com/forums/show...9+dash+sockets
which leads us to this :
https://www.americanautowire.com/sho...h-ground-wire/
ROB
69 El Camino
robpp is offline
post #6 of 14 (permalink) Old Dec 17th, 15, 1:25 PM Thread Starter
Bruce
Originally Posted by robpp View Post
So this one, while different, will work in the '68 dash sockets? All the ones that are stock only have one wire (assume power and grounded through the dash ground).
post #7 of 14 (permalink) Old Dec 17th, 15, 2:59 PM
Rob
I thought they were all the same......didnt notice you had one wire.
one wire must be the difference/ i have a dash in my crawl space but its too cold to check/ to confirm if same 68 69. but since they both had one year dash, who knows.
sorry for any confusion
ROB
69 El Camino
robpp is offline
post #8 of 14 (permalink) Old Dec 17th, 15, 3:02 PM
I did epoxy one back together with JB Weld many years ago on my 69 and haven't had any problems with it since.
post #9 of 14 (permalink) Old Dec 17th, 15, 3:11 PM
Rob
here is a single wire from AAW
http://www.americanautowire.com/shop...tact-socket-pl
ROB
69 El Camino
robpp is offline
post #10 of 14 (permalink) Old Dec 17th, 15, 4:49 PM
Bruce sent four Priority 3 day mail today, USPS might even deliver them by Christmas
The 2 terminal sockets are for the warning lights, IIRC maybe the GEN light since it does not have a body ground.
63 Nova wagon
Philip is offline
post #11 of 14 (permalink) Old Dec 17th, 15, 6:53 PM Thread Starter
Bruce
Thanks Rob, exactly what is in mine now!
post #12 of 14 (permalink) Old Dec 17th, 15, 6:55 PM Thread Starter
Bruce
Thanks Phillip, will let you know when they get here!
Might need replacements if I can't figure out how to setup the ones you send since they don't have the wire/terminal in them. At least I know I can get full replacements! :-)
post #13 of 14 (permalink) Old Dec 17th, 15, 7:02 PM
You will have to cut the wire in yours and feed it through the socket then solder it back together and insulate the wire. I also sent some contacts that fit in the socket but they are solid. Looks to be designed to have a female bullet connector attach to them.
63 Nova wagon
Philip is offline
post #14 of 14 (permalink) Old Dec 17th, 15, 8:50 PM
blm
Think Dorman makes a socket that works. Recall a thread on it. Try a search with word "Dorman". You could get them at local auto parts,
blm is offline
This Thread is more than 1669 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
