'71 mystery connector - Chevelle Tech
post #1 of 12 (permalink) Old Dec 13th, 15, 4:52 PM Thread Starter
Send a message via Yahoo to ElCameeeno
I have been studying wiring diagrams but have not been able to identify a connector in my '71 LS5/4speed engine harness (AAW factory fit harness). It's a two bladed female connector with one terminal having two tan wires and the other having a blue and green wire in it. Anyone know what this connector is for?
Jon
TC Gold Member #08
'71 SS454/M22 El Camino
'68 Chevelle/M22
'72 6 cylinder El Camino
ElCameeeno is offline
post #2 of 12 (permalink) Old Dec 13th, 15, 5:05 PM
Re: '71 mystery connector
Where in the harness is it?
63 Nova wagon
Philip is offline
post #3 of 12 (permalink) Old Dec 13th, 15, 5:19 PM
Hank
Picture would help
HKalin is online now
post #4 of 12 (permalink) Old Dec 13th, 15, 5:46 PM Thread Starter
Picture of connector
Jon
TC Gold Member #08
'68 Chevelle/M22
post #5 of 12 (permalink) Old Dec 13th, 15, 7:04 PM
Possibly the TCS system. If it is it would go to the solenoid that controls the vacuum to the distributor.
63 Nova wagon
Philip is offline
post #6 of 12 (permalink) Old Dec 13th, 15, 8:04 PM
Hank
Where about is the connector in the harness. I have a 71 Malibu and don't remember seeing a connector that looks like that on my AAW factory fit harness. I don't have the external regulator and that connector has a locking tab on it which I think the external voltage regulator may have. The only connector on my harness that has that locking tab is the alternator and it only has one wire going into each terminal.
post #7 of 12 (permalink) Old Dec 13th, 15, 8:53 PM Thread Starter
It breaks out of the harness at about the same place as the distributor wire. Near the tcs relays.
Jon
TC Gold Member #08
'68 Chevelle/M22
post #8 of 12 (permalink) Old Dec 13th, 15, 10:47 PM
Hank
You got me. My harness was also made up for an HEI distributor but even if it was points it wouldn't look like that. I know I have a couple wires hanging down behind my motor that I didn't use because the little box on the firewall was gone. I just looked in my 71 Chassis Service Manual and don't see anything in there either. I'll look at my harness tomorrow I know I have another spot where I have some wire hidden.
post #9 of 12 (permalink) Old Dec 13th, 15, 10:53 PM Thread Starter
Both my firewall relays are correctly wired up. I'll email AAW tomorrow, their tech support is pretty good. The mystery will be solved.
Jon
TC Gold Member #08
'68 Chevelle/M22
post #10 of 12 (permalink) Old Dec 13th, 15, 11:19 PM
Hank
Yeah, their good and their harnesses are right on. All the mounting clips are right in the right place. Good Luck
post #11 of 12 (permalink) Old Dec 14th, 15, 11:48 AM Thread Starter
Ok, so I heard back from AAW. That connector goes to the CEC solenoid mounted on the carb. I will be running a non-stock Holley carb so I will either tuck this wire out of sight or fab up a bracket and use it with the Holley. I am kind of intrigued with this CEC system and would like for it to function, the rest of it is there.... Also, I highly recommend AAW. Excellent quality and great customer support.
Jon
TC Gold Member #08
'68 Chevelle/M22
post #12 of 12 (permalink) Old Dec 15th, 15, 3:57 PM
Hank
Checked mine today, I do have that wire in my harness too but mine has a brown connector end with the locking tab on it not white.
This Thread is more than 1627 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
