Car Stereo Basics - Chevelle Tech
post #1 of 4 (permalink) Old Dec 11th, 15, 6:42 PM Thread Starter
von
Lifetime Founding Member
Von
Car Stereo Basics
I need a little education on basic car stereo systems. Normal listening volume, no metal rattling base, ear splitting loudness, etc. Just a radio (Retro Sound Hermosa 24 watts RMS/45 W peak X 4 channels), no amp, no sub, etc. For a given amp output from a radio, does a lower impedance speaker (say 3 ohm in lieu of 4 ohm) mean the speaker will perform better, be louder at the same volume setting, or ? Does a lower RMS amp range of a speaker mean it will sound better at lower amp inputs? What is a good frequency response number? Sensitivity? What speaker spec is the best to compare for good sound quality? Looking at 6 x 9 speakers.
von is offline
post #2 of 4 (permalink) Old Dec 11th, 15, 8:28 PM
Re: Car Stereo Basics
Von this I do know. My bass Amp is a ( German) Gallien Kruger. This amp is 200 Watts at 4 Ohms. I use a NEO. speaker. This speaker is 8 Ohms. Using an 8 Ohm speaker my amp power drops to 125 Watts.
With all amps, You can go up with the Ohm load but You cannot go lower the the designed load of the amp.
My amp wants to see a 4 Ohm. load for max power. Depending how you wire the speakers. If you wire them correct or as recomended by Mfg. You will have no issues.
Bottom line if my 4 Ohm. Amp sees a " 2 " Ohm. load, It will cook itself.
Mfg. may want each side, Stereo Ch. A /// Stereo Ch. -B Series or Paralell.
Von, You have untill spring to get this job done...... DONT RUSH IT !
Robinls5 is offline
post #3 of 4 (permalink) Old Dec 11th, 15, 9:18 PM
In an ideal world if you were to have 100 watts into an 8 ohm load then it should double into a 4 ohm load and then double again into a 2 ohm load and so on but no amplifier is 100% efficient.
Normally too when a load decreases it makes the amplifier run hotter and also will have it pulling more power.
These are just general statements as there are a lot of variables out there but if an amplifier is rated to run into a 4 ohm load, run it that way or with a higher load (8 ohms, 16 ohms, and so on). Some amplifiers can be run at a lower load than what is specified by the manufacturer and in those cases, you are kinda rolling the dice as to how things will last or what might or might not break.
A speaker has what they call a nominal impedance. Not to get too technical but a speaker at some frequencies may measure 4 ohms, at another frequency measure 3 ohms, and then at even another frequency measure 20 ohms or more but basically it's rated at 4 ohms and if you wire it to a radio rated to handle a 4 ohm speaker, all should be well.
Another specification of a speaker is sensitivity. Basically the higher the number, the louder it will be. A 4 ohm speaker with 92dB effeciency will be louder than another 4 ohm speaker with 89dB effeciency. Again, this is basic and what I would suggest is not to look super hard into the specs although things need to be compabible, but listen with your ears and buy what sounds best to you.
Another aspect on the system is making sure things are connected right and the speakers are mounted properly. I had a car in the other day that the customer said it sounds bad and he turned it on and right away I could tell some speakers were not wired properly. We faded the radio to the rear speakers and jacked up the bass and there was some bass coming out of both but when we went to just the left or the right speaker, the bass became more pronounced and louder. This told me one speaker was wired up backwards.
On rear deck speakers, or any speaker for that matter, they need to be mounted properly so that they perform properly. On the edge of the 6x9 speaker there is a flange and this flange must seal against the opening it's mounted to. On my 68 Nova I bought a replacement perforated rear deck cover and mounted the speakers to the underside of the metal package shelf. Due to the speaker I had to make a spacer since the tweeter protruded above the flange but basically the edge or perimeter of the speakers flange and the spacer sealed up against everything so that now the sound eminating off of the backside of the speaker cannot come into contact with the sound eminating off of the frontside of the speaker so it can create the most bass it can. In other words if the speaker is not mounted properly and it's just laying loose on the rear seat it will have good highs but the lower you go into the midrange and even lower into the bass sounds, it won't sound as well as a speaker mounted properly. Think of mounting a 6x9 like how you would put a motor together. You don't run a 6x9 laying loose, nor do you run a piston motor without rings.
Always working on something:
Jim Streib is offline
post #4 of 4 (permalink) Old Dec 14th, 15, 10:21 PM
Darren
Jim and Bob are exactly right. Just to expand on a few things they said:
Polarity reversal is the most common mistake people make. There is a + and for EACH speaker and it MATTERS. Less expensive head units may have a common – per side, higher end units usually have a separate – for each.
1 ohm stable amps are expensive because you can beat the crap out of them. Then there are speakers with up to 4 voice coils each… so you can essentially “tune” your system by running 1,2,3 of all of them to get the load you want on the amp.
You specified you didn’t want (or don’t have) an amp but it sounds as if you may be seeking more power? If the head unit is rated for 4 ohm per channel, and say you run “4”each 4 ohm 6x9 speakers in parallel to ONE channel you have essentially dropped the ohm rating/load to “-0” on that channel and it will likely fry, that’s not what it was made for. I hope that make some kind of sense, please just ask if you would like us to expound on anything.
If you don’t push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system – Boss 338 18’s - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I can’t remember
70 nialator is offline
This Thread is more than 1670 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
