LED Plug and Play 1971 Chevelle - Chevelle Tech
post #1 of 18 (permalink) Old Dec 2nd, 15, 3:54 PM Thread Starter
Lex
I am looking for a plug and play LED option for 1971 Chevelle. I do not want to cut up the harness. Please let me know what options there is. All I can find is you have to dice up the OEM harness.
dbprecision is offline
post #2 of 18 (permalink) Old Dec 2nd, 15, 5:25 PM
Re: LED Plug and Play 1971 Chevelle
For drop-in headlights:
https://www.chevelles.com/forums/sear...rchid=28648449
The Peterson 701C's horizontal center bar (inside the lamp, behind a totally clear and dead flat lens) aligns nicely with the body color stripe in the middle of the parking lights and the central stainless trim on the grill.
dogsridewith is offline
post #3 of 18 (permalink) Old Dec 2nd, 15, 9:02 PM
Pete
For your tail lights get 2 of these and call it a day.
https://www.superbrightleds.com/more...rofit-car/885/
They are very bright night or day.
Also get an LED turn-signal flasher
__________________________________________
1970-1 Chevelle (307ci w/PG) Now LS 6.0 w/4l60E
Progress Pics.
LS Swap
BigOiBoy is offline
post #4 of 18 (permalink) Old Dec 2nd, 15, 9:34 PM
Claude
Unfortunately, that link doesn't work… It has a message saying "Sorry - no matches. Please try some different terms") ...BUT I went on Peterson Manufacturing Company's website (here: http://www.pmlights.com/products.cfm...&pId=3748#701C) and there are three separate numbers listed M701C, M701C and V701C but there's no way to know what's the difference between them...
And last, it would've been nice to see them installed on a car!
Claude.
1971 Chevelle SS
toofastforyou is offline
post #5 of 18 (permalink) Old Dec 2nd, 15, 10:09 PM
Rich
http://www.amazon.com/Terminal-Signa.../dp/B004O1YTLW
My 68's tail lights aren't nearly as bright as people expect them to be, so I was thinking of these LEDs, too, as they are drop-in replacements. How does the turn signal flasher get wired in?
1968 Chevelle Malibu 454, mild cam, 30 over, 12-bolt 3.73 rear
1972 Chevelle Malibu 350, radical cam, 30 over, 10-bolt 3.55 rear
2007 Mustang GT, 4.6L (281), Stock
There are no Ford vs. Chevy wars in my garage. It's all U.S. muscle.
Proc is offline
post #6 of 18 (permalink) Old Dec 2nd, 15, 10:18 PM
Pete
Its plug and play. Pull out the flasher out of your fuse box and put the new one in.
Progress Pics.
LS Swap
BigOiBoy is offline
post #7 of 18 (permalink) Old Dec 2nd, 15, 10:32 PM
Pete
Here are those bulbs at noon time on a sunny day.
Click on the image to see the video
[IMG][/IMG]
If your looking for plug and play disregard the halo's i also have in the
housing, those require some splicing and hot glue.
Progress Pics.
LS Swap
BigOiBoy is offline
post #8 of 18 (permalink) Old Dec 2nd, 15, 10:39 PM
Claude
Then you should go with THIS: https://digi-tails.com/1968-chevy-ch...l-light-panels
Claude.
1971 Chevelle SS
post #9 of 18 (permalink) Old Dec 3rd, 15, 2:24 AM
Vince
hey Proc check this link;
these were installed in my 68malibu
https://www.chevelles.com/forums/showthread.php?t=751882
VinceS427bb is offline
post #10 of 18 (permalink) Old Dec 3rd, 15, 6:45 AM
Re: LED Plug and Play 1971 Chevelle Peterson
Sorry. I just tried another way to post results of an advanced search and it didn't work either. So, this is what to do. Click search. Click advanced search. Write dogsridewith on the right side menu. Write Peterson on the left side menu. Click search. Presto...there's everything I've posted here about these things.
(The different 701C part numbers were just Peterson's packaging or quantity variants)
Claude.
post #11 of 18 (permalink) Old Dec 3rd, 15, 7:45 AM
Rich
Wow! That is exactly what I was hoping for. Thanks!
Proc is offline
post #12 of 18 (permalink) Old Dec 3rd, 15, 9:05 AM
Claude
"Click search. Click advanced search. Write dogsridewith on the right side menu. Write Peterson on the left side menu. Click search. Presto...there's everything I've posted here about these things.
Nope…doesn't work, sorry. I keep getting a "Sorry - no matches. Please try some different terms" message…
Claude.
1971 Chevelle SS
post #13 of 18 (permalink) Old Dec 3rd, 15, 9:19 AM
still works for me. gives 10 results. first "advanced search" on menu. write "dogsridewith" in Username block on top right. write "Peterson" in keyword block on top left. Click show posts. click search.
post #14 of 18 (permalink) Old Dec 3rd, 15, 11:28 AM Thread Starter
Lex
Claude.
Is this plug and play?
post #15 of 18 (permalink) Old Dec 3rd, 15, 11:29 AM Thread Starter
Lex
[IMG][/IMG]
What color LED did you buy? Appears very bright.
1) Unscrew old bulbs
2) Screw in LED bulbs
3) Pull out Blinker Switch
4) Install new blinker switch
Is that is for install?
This Thread is more than 1644 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
