Starter Trouble - Page 3 - Chevelle Tech
post #31 of 37 (permalink) Old Dec 26th, 15, 1:49 PM
mark
Re: Starter Trouble
If its a stroker 454 it might be neutral balanced.If it did not vibrate before with the old flywheel it may be an external bal.and the flywheel you have now might not be
1965 malibu,03 silverado ss
M.J. 496
th350,4.11 3250lbs,+185 FOR ME
28x10.5 Hoosiers
9.85,135.50,1.35
mino65 is offline
post #32 of 37 (permalink) Old Dec 29th, 15, 11:15 AM Thread Starter
Binu
Re: Starter Trouble
I was wondering about that but seems the last one was also externally balanced. Im just thinking if they milled some of the new one for better engagement, that would effect the balance right? The shop kept saying that they are not aware what crank is in the engine and it seems to protrude out more than others. Looking at the paperwork it seems to a scat cast steel crank series 9000/externally balanced. Are there specific flywheels that may work better with this setup?
bja72774 is offline
post #33 of 37 (permalink) Old Jan 5th, 16, 3:51 PM Thread Starter
Binu
Re: Starter Trouble
So funny story, the turndows that were installed were facing out each side, and for some reason that rattle made me think something was vibrating. I ended up turning them so they just go out the back and it seems to be better.
Argh...now, regarding the starter...it now seems to hesitate before starting. This didnt seem to happen before, possibly shimmed wrong or maybe check the gear mesh gap again? Battery has good voltage so cant be that.
Also i have been looking at starter videos and it seems that the engagement between the starter and the flywheel should be atleast 1/16th and go up to 3/8ths when cranking. So thats how my starter was before it blew a tooth of the gear....and the shop said there wasnt enough engagement. Am I missing something...
bja72774 is offline
post #34 of 37 (permalink) Old Jan 5th, 16, 3:59 PM
Re: Starter Trouble
If the starter engages and hesitated to crank the engine when hot, it may be that your timing is a bit too advanced, the engine is wanting to kick back. Engagement should be 1/16, basically if you install a drill bit at the end of the tooth on the starter in the pocket between 2 teeth in flex plate.
oldcutlass is online now
post #35 of 37 (permalink) Old Jan 5th, 16, 4:55 PM Thread Starter
Binu
Re: Starter Trouble
Strange thing was the engine was cold... sorry for all the questions....
bja72774 is offline
post #36 of 37 (permalink) Old Apr 28th, 16, 9:13 AM
Re: Starter Trouble
How To Ask Questions On This Forum?
milkman is offline
post #37 of 37 (permalink) Old Apr 28th, 16, 10:35 AM
Andy
Re: Starter Trouble
I have one CVR and four Powermasters. Both are pricey but worth it.
Andy's Auto Repair is offline
This Thread is more than 1208 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
