Tachometer - Chevelle Tech
post #1 of 2 (permalink) Old Sep 20th, 15, 10:52 AM Thread Starter
Dean
Tachometer
My '70 SS396 has a later version GM HEI rather then the points system. My tach does not read accurately. Is there something I need to change? Seems to read higher than it should.
dbuchholtz is offline
post #2 of 2 (permalink) Old Sep 20th, 15, 1:01 PM
Re: Tachometer
Yes, google search for "gm tachometer problems with gm hei". Could be you need a very easy to build, low cost filter, or resistor to drop the signal down to the correct level.
Dave Ray is offline
This Thread is more than 1617 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
