HEI TACH output high voltage - Chevelle Tech
post #1 of 7 (permalink) Old Sep 14th, 15, 8:07 AM Thread Starter
Unhappy HEI TACH output high voltage
Im measuring high voltage on TACH output, is it possible? I measured as high as 1000v dc, measuring beetwen +12 and TACH, Anyone knows how to solve that? Is it the coil issue? module? Itś a big issue Ill fry another Tachometer if I connect again...
sergiolitwiniuk is offline
post #2 of 7 (permalink) Old Sep 14th, 15, 6:34 PM Thread Starter
Re: HEI TACH output high voltage
I want to add,... the engine is a 67 small block chevy 283, the distributor is an aftermarket hei from summit racing, http://www.summitracing.com/int/parts/sum-850001r ,
post #3 of 7 (permalink) Old Sep 14th, 15, 6:42 PM
With a bit of luck, Dave Ray will be able to answer your question. He is very well informed on ignition technology. I am thinking that there should be a capacitor to absorb that 1000V spike that you are seeing. Are you using a peak reading voltmeter to get that number?
JWagner is offline
post #4 of 7 (permalink) Old Sep 14th, 15, 6:45 PM
Gary
Theres going to be a high voltage if you check it like that. When a coil fires it produces voltage on the primary side too. Whats the actual problem?is the tach not working
gnicholson is offline
post #5 of 7 (permalink) Old Sep 15th, 15, 1:10 AM Thread Starter
The problem is that i bougth a new tachometer then connected to the tach output and it never worked.. So i went to to the seller and he gave me a new one. I measured the output and realizado that maybe the high voltage caused malfunction un the precios tach.. So i don't want to fry a new tach.. That's all
post #6 of 7 (permalink) Old Sep 15th, 15, 1:15 AM Thread Starter
I am using a normal dc voltmeter, i don't have another small block engine with an hei to measure if that output is normal
post #7 of 7 (permalink) Old Sep 15th, 15, 2:35 AM
Gary
What kind of tach are you using? Some tachs including the factory need a filter or resister do to the high voltage on the tach terminal
This Thread is more than 1627 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
