New member. Wiring question - Chevelle Tech
post #1 of 7 (permalink) Old Sep 6th, 15, 12:27 PM Thread Starter
Mark
Hey all. Finally registered. Have used this forum quite a bit and have found it quite helpful. I am at a loss on this question though.
I bought a 70 SS back in June. Not a matching number in the car. I replaced a th400 with a tremec tko600. Added vintage air. Replaced the engine harness. Bought an aftermarket instrument cluster with gauges. Buttoned it up and and found my temp gauge and ammeter not working. Did some homework and learned that the temp sending wire on indicator to gauge conversions are in the front headlight harness. OK cool. Purchased a new harness from American auto wire. Everything fit well except I had to extend the wires for the indicator and running lights on both sides.
Here is my dillemma. First off, I suck at all things electrical. Prior to the new harness I had one heavy gauge wire to the alternator. This came from the new engine harness. The alternator is internally regulated. The new front headlight harness also has 2 alternator leads. One lead is a 2 wire with blades. Plug and play. Then there is another heavy gauge red wire that looks like it is supposed to hook up directly to the main post on the alternator. All of my Google searching only shows 1 wire going to that post. I'm reluctant to just blindly attach this wire for fear of frying something.
Any advice?
By the way, the car runs great and I put in a new 4 core aluminum radiator. I let it idle with the AC on for an hour and jury rigged a thermocouple where the temp sender is. Hottest it got was 170, so I'm not worried about overheating. I just want my gauge to work.
Newoldguy is offline
post #2 of 7 (permalink) Old Sep 6th, 15, 12:29 PM
leo
Re: New member. Wiring question
Call American Autowire and ask, good luck.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #3 of 7 (permalink) Old Sep 6th, 15, 12:46 PM Thread Starter
Mark
I know. They are closed and I am in the process of connecting the harnesses to the firewall bulkhead. Then I'm an hour from firing it up.
post #4 of 7 (permalink) Old Sep 6th, 15, 6:40 PM
Russ
Standard GM alternator configuration is the two blade connector plugged into the reg and the large red lead onto the post on the back of the unit. Many one wire units have the regulator connector plugged and bypass it internally so they don't use the two blade connector at all. Other one wire conversions route one of the two wires going into the regulator back onto the post on the rear of the alternator as a jumper. Without knowing your alternator deign I am not sure what to tell ya.
My project pics are here:
Thumpin'66 is offline
post #5 of 7 (permalink) Old Sep 10th, 15, 9:08 PM
Was the engine harness a stock replacement or the update kit? The update car harness I just replaced, has an extra 12 ga wire as the battery source for an electric fan.
ACES #00140
TEAM CHEVELLE #0038
rick is offline
post #6 of 7 (permalink) Old Sep 11th, 15, 4:36 AM
ever nptice we have different sections for different types of questions?
Moving to Electrical.
post #7 of 7 (permalink) Old Sep 11th, 15, 10:28 AM
Randy
Thanks for your diplomatic response to our new member.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
This Thread is more than 1721 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
