Connecting a new vintage radio to a stock radio harness on 70 chevelle - Chevelle Tech
post #1 of 6 (permalink) Old Jun 14th, 15, 11:15 PM Thread Starter
Just purchase a radio from antique automotive radio. Is there suppliers who make a connector from the new 12 pin connector to the stock wiring harness on my 70 chevelle. Just bought new wiring harness and would prefer not hack into it. It is a 4 speaker system
Wrrossi
Bill Rossi is offline
post #2 of 6 (permalink) Old Jun 15th, 15, 11:16 AM
Re: Connecting a new vintage radio to a stock radio harness on 70 chev
What speaker system is in the car now?
What are your plans and LOCATIONS for speakers ?
70 2 drs. and 4 drs. had a stand alone stereo harness. This harness would help. It would locate the wires in the correct location and you would have FOUR speaker connections. Or get some Silver / Gold speaker wire and have at it.
Doing a Nice & Neat install in VERY time consuming. Removing a lot of parts & Pieces.
Or a fitz / All harness, Then start to solder. Many ways to do this install.
You pick what is best for you. Speaker, Ohms load?
Robinls5 is offline
post #3 of 6 (permalink) Old Jun 15th, 15, 8:16 PM Thread Starter
I have a 70 2 dr and wired using 4 speaker harness from M&H wiring. I have not purchased speakers yet . Was hoping for a plug & play as opposed to actually removing the connectors in the new harness from M&H. Never know, might change my mind in future and install an original radio. Thanks for the input
post #4 of 6 (permalink) Old Jun 15th, 15, 8:41 PM
Wrrossi
Even if they did, this wouldn't work.
The original audio systems in these cars use a non-floating ground which means each (-) side of each speaker actually returns back to chassis ground.
Modern audio uses a floating ground, each speaker has two dedicated wires completely isolated from chassis ground. Grounding a speaker connection in any manner on a modern stereo will instant result in you have a much lighter wallet immediately.
Even if you were to ensure isolation--The '70-72's rear speaker harness only has (3) wires, a common ground, then a left (+) and the right (+). That common shared ground would most definitely foul things up. In the very least you will have to run an additional wire to the rear deck so there would be a total of (4) wires available to you--2 independent wires for each speaker.
You may have to upgrade your speakers as well for un-objectional audio quality with a more powerful stereo. The factory units used 10 ohm speakers. Modern speakers are 4 ohms to provide more power dissipation.
Coppertop is offline
post #5 of 6 (permalink) Old Jun 15th, 15, 9:17 PM Thread Starter
Good information and the operating instructions for the new radio is clear not to use original speakers and to use 4 ohm speakers.
post #6 of 6 (permalink) Old Jun 16th, 15, 8:44 PM Thread Starter
Thank you for the information. Definitely makes sense the way you explained it.
This Thread is more than 1851 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
