classic fit from AAW - Chevelle Tech
post #1 of 5 (permalink) Old Jun 11th, 15, 10:19 AM Thread Starter
robert
Send a message via AIM to monte7ocar Send a message via Yahoo to monte7ocar
I'm working on my second install of an America Autowire classic fit system in a 72 Monte that I'm building. I seem to have an extra flasher left double checked the harness and the sheets and there is no call for the other flasher just one in the fuse box which is there. Also has anyone try to reuse the original seat belt light.
1970 el camino
monte7ocar is offline
post #2 of 5 (permalink) Old Jun 11th, 15, 11:59 AM
Greg.
Re: classic fit from AAW
Maybe Donnie at AAW can answer your question(s) better !
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #3 of 5 (permalink) Old Jun 11th, 15, 12:24 PM
The flasher on the fuse box is for the four way hazard lights.
The turn signal flasher is hanging by the harness that it's plugged into.
post #4 of 5 (permalink) Old Jun 13th, 15, 9:21 PM
Which kit do you have?
There is a Classic Update and a Factory Fit. One is modernized for custom wiring, the other is stock plug 'n play...... There's no "Classic Fit".
Coppertop is offline
post #5 of 5 (permalink) Old Jun 14th, 15, 7:16 PM Thread Starter
robert
It's the classic update. It looks as if the system only takes one flasher and that is what I recall from the other kit I put in as the flasher uses a 15amp fuse.
1970 el camino
This Thread is more than 1688 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
