1967 chevelle 300 Deluxe wiring question - Chevelle Tech
post #1 of 5 (permalink) Old Jun 8th, 15, 7:44 PM Thread Starter
Okay just completed removing Inline six, Installed 5.7L with that the exchanged engine has different alternator with built in Regulator, also starter only has battery and 1 small screw for wire, I am guessing that one of my previous wires goes to the small one and the other connect with the battery so when the key is turned it will engage, but what about the wires that were previous to alternator, I know the car has voltage regulator in engine compartment, so how do I connect to the new alternator without blowing my system, I will be keeping the newer alternator, right now I put 12v to HEI from battery and hand remote starter and car runs fine, but need to hookup wires properly how to convert?
Bradco is offline
post #2 of 5 (permalink) Old Jun 8th, 15, 7:50 PM
Keith
Re: 1967 chevelle 300 Deluxe wiring question
Just use your original alt and save your self a headache.
Maryland Chevelle Club #682
keithb is offline
post #3 of 5 (permalink) Old Jun 8th, 15, 8:46 PM Thread Starter
the new one is serpentine system, I would have to change all the brackets and water pump, will do that in the future, but not now
Bradco is offline
post #4 of 5 (permalink) Old Jun 8th, 15, 8:57 PM
Keith
Oh. the major electronical vendors sell a kit that's plug and play. Or search the interwebs to rewire it your self
keithb is offline
post #5 of 5 (permalink) Old Jun 8th, 15, 11:03 PM
Rob
You should be able to use the Mad enterprises alternator wiring kit to up date your wiring to work with the newer alternator.
http://madelectrical.com/catalog/alt-1.shtml
My build thread> https://www.chevelles.com/forums/showthread.php?t=613546
65chevelle300post is offline
This Thread is more than 1478 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
