1968 El Co Ignition/Power Issue - Chevelle Tech
post #1 of 10 (permalink) Old Jun 4th, 15, 11:02 AM Thread Starter
Gilbertt
Hi Guys, i'm new to this group of El Co's. I just picked up a '68 SS Clone, 396 4 spd car.
Car was not running when I went to see it. Previous owner thinks there is an ignition switch problem. So I got the car to turn over with a remote starter.
With my test light there is a real weak light at the fuse box. When I turn the key to start it, there is no power at the fuse box. When I turn on the Hazard flasher switch, there is no power at the fuse box either. This leads me to believe this is not specifically an ignition switch issue.
Now, there is only 1 ground strap that I can see from the body to the block and I don't see one from the frame to the body.
Can this be causing the loss of voltage to the fuse box? Or is it that there may be a short somewhere? I'll start with the ground strap but any other suggestions would be great! thanks in advance.
MrGee is offline
post #2 of 10 (permalink) Old Jun 4th, 15, 1:48 PM
Steve "Dirty"
Re: 1968 El Co Ignition/Power Issue
Check your inline fusible links. One is next to horn relay and another is next to battery.
68 SS427 Chevelle
5.3 LS 84mm Billet Turbo
55 Chevy Field car
"Another One Back On Jack Stands"
But you'll appreciate me soon. You're gonna be hangin' on for mercy when I get this sucker rollin'.
The internet is like the Bugs Bunny Show "AAH Could Be"
modchevelle is offline
post #3 of 10 (permalink) Old Jun 4th, 15, 1:51 PM Thread Starter
Gilbertt
Will do thank you Modchevelle!!
MrGee is offline
post #4 of 10 (permalink) Old Jun 4th, 15, 4:30 PM Thread Starter
Gilbertt
One question, if the fusible links were bad or blown, I wouldn't have power to the fuse box correct?
MrGee is offline
post #5 of 10 (permalink) Old Jun 4th, 15, 4:37 PM
Sounds like bad connections at the bulkhead connector.
post #6 of 10 (permalink) Old Jun 4th, 15, 7:39 PM Thread Starter
Gilbertt
At the fusebox? Or the bulkhead from the fusebox? or am I way off?
MrGee is offline
post #7 of 10 (permalink) Old Jun 4th, 15, 8:06 PM
David
Check both sides. I rewired my 68 and none of the engine lights and other front electric worked. It was a loose bulkhead in engine bay which I believe is connected by two bolts.
Check the fuse box also which is connected by two screws. Good luck.
Dnrice is offline
post #8 of 10 (permalink) Old Jun 4th, 15, 10:20 PM
Steve "Dirty"
I had a wiring harness that had a fusible link hanging on by a strand or two next to the horn relay. Electrical problems suck..I know I've been working on mine for days.
68 SS427 Chevelle
55 Chevy Field car
post #9 of 10 (permalink) Old Jun 5th, 15, 12:07 AM
Brent
Electrical problems are easier solved with a wiring diagram. At least you can trace the particular circuit, and using a voltmeter, find the problem. Maybe you can find one online, I don't know. Sounds like your dealing with a poor connection, broken wire, something of that nature.
rookie chevelle guy is offline
post #10 of 10 (permalink) Old Jun 9th, 15, 7:19 PM Thread Starter
Gilbertt
Thanks Dnrice, I will try this, seems to be a popular choice!
Thanks modchevell, I will look at this first, probably then head to the bulkhead!!
Thank you Rookie chevelle, good possibility, it definitely seems a novice wirer has been under the hood and under the dash.
Just strange to me that not only does power stop when turning the key, it also stops when i put hazard switch on.
MrGee is offline
This Thread is more than 1477 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
