'66 gauge conversion kit ? - Chevelle Tech
post #1 of 7 (permalink) Old Nov 16th, 14, 8:55 AM Thread Starter
Mitch
Looking to do the gauge conversion. I see The Parts Place is advertising theirs has metal housings, as original. Some are plastic.
Anyone that has done this conversion, are you happy with what you got ?
Are the metal housings a better product ?
70 Chevelle SS 396, M20 Oshawa built Z25 project.
66 Chevelle SS 396, Atlanta built 138 driver/project.
67 Camaro, ss/rs 350 LA built driver/project.
62 Impala SS with a transplant 409
1954 210 2 dr sedan 292 6 cyl, straight axle project
38 Chev coupe...355, 200r4, 8.5" 3.42 posi
69 Chev C10
89 R3500 roll back car carrier
Second_chance_SS is offline
post #2 of 7 (permalink) Old Nov 16th, 14, 9:22 AM
"Wild Bill"
Re: '66 gauge conversion kit ?
I've used the Shiftworks gauge conversion kit in a couple '66-67 Malibus...good stuff!!
They are metal.
BTW...recommend getting the Voltmeter version. Easier and safer to install.
http://www.shiftworks.com/gauges-ss.htm
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #3 of 7 (permalink) Old Dec 18th, 15, 2:03 PM
Kelly
Does anybody make a SS Gauge Conversion kit for a '66 but with electric oil pressure gauge?
66' Chevelle 2 door Sport Coupe BBC/TKO600
all4sho is offline
post #4 of 7 (permalink) Old Dec 18th, 15, 3:52 PM
Dale
Not that I've seen. FWIW, the is no "SS Gauge Conversion" for 66 or later Chevelles. Neither SS396s nor SS optioned Chevelles came with gauges. Gauges were an option on ANY Malibu and SS396 sport coupe, convertible, pickup with a V8. In 66, one could get the U14 gauge option on the L6 as well; the L6 in 66 just couldn't get a tachometer.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #5 of 7 (permalink) Old Dec 18th, 15, 3:55 PM
I haven't see one.
Are you worried about the mechanical gauge? Leakage?
I ended up running copper tubing (instead of plastic). I once even added a "T" so I could use the stock in-dash gauge with a normal aftermarket gauge with pressure readings...
Once I had the lines snugged up, I never had a leakage issue...
TC #1366
Sold
Sold
1966_L78 is offline
post #6 of 7 (permalink) Old Dec 18th, 15, 3:59 PM
True...
Be aware, there are some "conversion" kits on the market, as well as some "replacements"... The "replacements" will require new, correct "gauge" wiring harnesses, etc, unless you already have factory gauge stuff... They are to replace factory gauges (duh)...
The "conversions" are made to convert non-gauge, idiot light cars to the look of in-dash gauges... Of the conversions I have seen, Shiftworks looks the best, but I haven't looked around for a few months.
BTW, I realize the original post is many years old, but I place this info here so that someone using the "search" function may still have more information...
TC #1366
Sold
Sold
1966_L78 is offline
post #7 of 7 (permalink) Old Dec 18th, 15, 9:03 PM
Kelly
Sorry Dale, i meant gauge conversion instead of lights
thanks for the info 1966_L78,
and yeah i was not really wanting oil on the inside of the car, but as far as a harness goes i am going to be using a Autowire Classic update series harness so i hope i have what i need to make it all work
"I HOPE" seams to be alot lately with this project
all4sho is offline
This Thread is more than 1668 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
