Rear turn signal/brake light problem - Chevelle Tech
post #1 of 4 (permalink) Old Aug 19th, 14, 10:39 AM Thread Starter
Ricardo
I have a 65 chevelle and I'm trying to fix some issues.
My front turn signals work fine.
All the lights work when I turn them on.
The problem I'm having is with the rear turn signals/brake lights.
Any ideas?
Monte888 is offline
post #2 of 4 (permalink) Old Aug 19th, 14, 10:46 AM
Bryan
Re: Rear turn signal/brake light problem
If all grounds are okay
If your gas gauge works
If your dome lights work
Turn switch is probably bad
Make sure it is connected securely----probably is if the front turns work, but double check.
Brake lights go thru the turn switch and that portion of the switch needs to be working or there will be no brake lights-----or rear turns.
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done
On the street now!!!
Bryan59EC is offline
post #3 of 4 (permalink) Old Aug 19th, 14, 1:23 PM Thread Starter
Ricardo
Could it be possible that it has the wrong bulb?
I checked the wires behind the bulb and it blinks with the turn signal.
Monte888 is offline
post #4 of 4 (permalink) Old Aug 19th, 14, 1:58 PM Thread Starter
Ricardo
Solved!!
It had the wrong bulbs.......
Monte888 is offline
This Thread is more than 2050 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
