New Costom Autosound USA 630 wiring questions - Chevelle Tech
post #1 of 7 (permalink) Old Aug 17th, 14, 1:31 PM Thread Starter
Mark
I have a new Costom Autosound USA 630 sound system that I've installed in my 72 Malibu. I would like to ask for help with the wiring. On the original wiring harness, there is a black (ground) wire, a yellow (power constant of switched) wire and a gray (?????) wire. From what I have read on this site, the gray wire was used with the original radios to provide light to the display when the lights were turned. I would like to know if the yellow wire goes to the ignition and in only hot when the switch is on. I also read that all orange wires in the harness are hat all the time. Is this true? Now to the wires on the back of the radio. There are three wires labeled ignition, battery and ground. Someone please let me know which ones to hook where.
Thanks Mark
Scoutmaster 442 is offline
post #2 of 7 (permalink) Old Aug 17th, 14, 2:16 PM
Re: New Costom Autosound USA 630 wiring questions
Mark,
For future reference, this needs to be posted in Electrical.
Ground connects to the factory black
Switched ignition connects to the factory yellow
Battery connects to "BAT" connector on fuse block, or splice into orange dash wiring.
The factory gray is not going to be used unless the radio has a provision for a dimmable lighting input. Tape off the gray so it doesn't short out.
Coppertop is offline
post #3 of 7 (permalink) Old Aug 17th, 14, 3:46 PM Thread Starter
Mark
That's what I thought but I just wanted to verify? This was the first time I had started a thread. I'll do better next time.
Thanks Mark
post #4 of 7 (permalink) Old Aug 17th, 14, 7:37 PM
No worries Mark.
post #5 of 7 (permalink) Old Aug 17th, 14, 7:58 PM
are you Scoutmaster of a BSA Troop? Maybe Troop 442 out of Union, Mo?
post #6 of 7 (permalink) Old Aug 17th, 14, 8:02 PM
moving your thread to Electrical so others might find it later. As always, good info from Coppertop.
post #7 of 7 (permalink) Old Aug 17th, 14, 8:14 PM Thread Starter
Mark
Tom, to answer your question. I was the SM of Troop 442 in Union, MO but, recently retired after fifteen years with the Troop. I'm stiil invlolved with Scouts at District level. Thanks for moving it over to electrical. I'll take all he help in getting my ride back on the road. If you want to see my Malibu, I posted an electrical question this afternoon too.
Mark
This Thread is more than 2056 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
