Silly Fuel Gauge - Chevelle Tech
post #1 of 3 (permalink) Old Aug 15th, 14, 1:03 PM Thread Starter
Ken
Silly Fuel Gauge
I had a leaking rubber vent line on my tank, so I removed the tank, replaced all the rubber lines and put the tank back up. Fuel gauge worked fine prior to removal, now when I fill the car it only goes up 3/4 of the way on the gauge.
I did this a few weeks ago in hopes it would correct it's self by getting bounced around, but nadda. <--- love it when things just "self fix"....
Any idea's?
thanks
Ken
71 Chevelle 454 gen v
- 215 gen IV heads
-TKO 5 speed, 3:73 posi 12 Bolt
-2.5" SS magna flow's
-750 Holley/vac
-Comp Cam D:IN-296 EX-302 Lift:IN-566 EX-566
-Timing 18*/38*
-Hydraulic Roller's
-Comp Cams Roller Timing set
-Crane Roller Rockers
-Edelbrock RPM Air Gap
-Boss 18's with MT's
Boilermaker128 is offline
post #2 of 3 (permalink) Old Aug 16th, 14, 8:02 PM
Re: Silly Fuel Gauge
Any idea's?
thanks
Ken
Ken,
What you're describing sounds like a fault of the sending unit. If the ground connection was bad, you've have a too full indication on the gauge.
Have you tried the test that has been outlined countless times on this site that let's you know if the gauge is working properly?
Coppertop is offline
post #3 of 3 (permalink) Old Aug 18th, 14, 12:55 PM Thread Starter
Ken
Originally Posted by Coppertop View Post
Ken,
Hi Joe,
Nope, I have not tried any tests yet... I'll seach around and see what I can dig up. It's not a big deal, just thought it was weird. I'll add it to my "things to do list" for the winter.
- 215 gen IV heads
-750 Holley/vac
-Timing 18*/38*
-Hydraulic Roller's
This Thread is more than 2049 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
