Factory power window issue - Chevelle Tech
post #1 of 5 (permalink) Old Aug 15th, 14, 2:21 AM Thread Starter
Hoping some of you guys can help me sort an issue I'm having with my '69 Chevelle that was optioned with factory power windows.
All the windows used to work from the drivers door panel but now only the drivers door window works from the drivers door panel. However, the passenger door window and quarter windows all still work from their respective switches.
Would this be a faulty drivers door switch? If so can I just replace the piece in these pictures or is it usually the chrome switches themselves that go bad? Or there's the plastic electrical socket that the pins plug into?
Any input would be much appreciated, cheers.
ID:	193290   Click image for larger version
_________________
'69 SS396 Chevelle
R/H DRIVE SS396 is offline
post #2 of 5 (permalink) Old Aug 16th, 14, 7:25 PM
Re: Factory power window issue
Have you inspected the plug and wiring behind the switch itself? The driver's control "center" is in parallel with the wiring controlling the other windows, so it's not unusual that each respective switch/window still works, but not from the "master control center". Typically the contacts inside burn from use and no longer work, but you'd think if anything, the driver's side switch would go first. That's why I'm suggesting taking a look at the wiring/connector.
Coppertop is offline
post #3 of 5 (permalink) Old Aug 16th, 14, 10:20 PM Thread Starter
Thanks for your reply Joe. I'll have a look at the connector, what would I be looking for, loose/disconnected wires and signs of burning?
Cheers
_________________
'69 SS396 Chevelle
post #4 of 5 (permalink) Old Aug 17th, 14, 8:40 PM
Cheers
Yes, check for any signs of corrosion, heat, discoloring, loose connections etc. I don't have the colors off hand, but you could take a jumper wire and short from the "common" power connection to each "up" and "down" connection to see if the respective windows respond, if they do, you know there's something going on with the switch or how it mates to the connector and not with the wiring coming into the driver's door.
post #5 of 5 (permalink) Old Aug 18th, 14, 7:14 PM Thread Starter
OK, thanks for the additional info. I'll see if I can locate the problem doing what you suggested.
_________________
'69 SS396 Chevelle
This Thread is more than 2055 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
