Battery ? - Chevelle Tech
post #1 of 6 (permalink) Old Aug 12th, 14, 5:56 PM Thread Starter
George
Battery ?
I would like to know where the small wire on the positive post on the battery goes and there is a relay on the drivers side next to the volt reg what is it my 69 el camino has a short it's a 12 volt draw and help would be great thanks geo
Gbsr1933 is offline
post #2 of 6 (permalink) Old Aug 12th, 14, 8:15 PM
Re: Battery ?
On 70 El Caminos & Chevelles it goes to the core support, Just to the right of the Batt. You will find a terminal block (on the core support) with a small nut and a wire attached. When you attach your + wire to this, It will feed 12 Vts. to the interior, Ign.--lights-- fuse block,-- Horn relay,etc. Now you will say, OH S#!T, Now I remember.
Robinls5 is offline
post #3 of 6 (permalink) Old Aug 12th, 14, 8:42 PM
Re: Battery ?
The relay on the drivers side is the horn relay.
70 Chevelle SS396, L34
73 Camaro Z-28
32 Ford Model B Pickup
post #4 of 6 (permalink) Old Aug 12th, 14, 11:36 PM
Vince
Re: Battery ?
is it a headlight relay wired into the system?
VinceS427bb is offline
post #5 of 6 (permalink) Old Aug 12th, 14, 11:57 PM
Re: Battery ?
What you are calling a "short" in the horn relay (current drain) could be something upstream since the "BAT" terminals on the horn relay serve as a terminal to feed power to the bulkhead connector, then onto several other things.
{EDIT} Guess that would be downstream, not upstream.
post #6 of 6 (permalink) Old Aug 13th, 14, 12:07 AM
Re: Battery ?
There's no such thing as a "12 volt draw".
Current is a draw, typically measured in amps for automobiles.
A 12 amp draw would be quite considerable and drain the battery very quickly.
The set-up works like this:
A 14 ga. fusible link from the battery (+) to a junction block behind the battery powers everything in the car but the main starter power feed. At the junction block, the fusible link meets up with a 10 ga. red wire that runs across the radiator support to the horn relay which has screw terminals and splices that distribute power to all vehicle components.
Coppertop is offline
This Thread is more than 2052 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
