Need help wiring. Amp guage with a 1 wire alternator - Chevelle Tech
post #1 of 14 (permalink) Old Jun 2nd, 14, 2:14 PM Thread Starter
Richie
Im trying to wire up my Amp guage thats in my dash. One wire went to the horn relay and the other to the positive side of the battery. I turn on the lights and it reads a discharge value, But when I start the car it never shows a charge value alwas a discharge. If I shut the lights off the guage almost goes to 0. I use a 1 wire generator straight to the battery terminal. Just for testing we pulled up another chevelle with the 3 wire alternator. I ran my wires over to his car. I wired it the same way and it worked fine. Showing charge and discharge value. So How do I modify my installation to my system so it can show charge and discharge value?
Rich NYC
N2ROW is offline
post #2 of 14 (permalink) Old Jun 2nd, 14, 2:38 PM
Jerry
Re: Need help wiring. Amp guage with a 1 wire alternator
Perhaps the culprit is the one wire alternator. It's been a while since I did the complete re-wire of my 64, but I recall quite a few threads discussing the merits/disadvantages of the one-wire set up. Maybe check out those threads to see if it answers your questions. I ended up using a voltmeter and a 3-wire alternator. There is a website called Madelectrical.com that has a ton of great information about Chevy charging systems. That helped me alot. Good luck!
Jerry
757driver is offline
post #3 of 14 (permalink) Old Jun 2nd, 14, 2:48 PM
Maybe a moderator will move this to the proper forum.
Schurkey is offline
post #4 of 14 (permalink) Old Jun 2nd, 14, 2:56 PM Thread Starter
Richie
I searched only under Chevelle Tech. Other than Internet. I further checking as I wait for some ideas.
1971 Chevelle (Heavy Chevy) SS Clone
400 ci small block 6.6/400 Turbo Trans
Dual Quad Edelbrock carb, 373 gears
N2ROW is offline
post #5 of 14 (permalink) Old Jun 2nd, 14, 9:01 PM
Call MadElectrical. There is more to this than you think. I would put a 3wire back on.
Good luck,
Jon
jonh is offline
post #6 of 14 (permalink) Old Jun 2nd, 14, 9:31 PM
Why call MAD?
This simply needs to be posted in the correct area (Electrical) and we'll give you all the info you need.....no charge.
Moderator, please lock/move this......
Coppertop is offline
post #7 of 14 (permalink) Old Jun 3rd, 14, 12:01 AM
Donny
Rich NYC
The problem is probably not the 1-wire alternator. I'll take it from your post that you are using some type of non-original wiring harness, other wise, you would just have to connect the red wire. The issue is that an aftermarket harness will not work with a stock ammeter, period. The stock harness had a shunt built into it by the way the harness was designed, laid out, and constructed. A non original harness does not route the charging circuit the same way, consequently, the gauge cannot see the draw vs. the charge in a system. Plus, ammeters are a bad choice to monitor your charging system when using a 1 wire or other internally regulated unit. Most of those alternators are 100 amps or more, and the OE's stopped using them and went to a voltmeter for a reason as the alternators began getting more powerful.
Donny
aawtech is offline
post #8 of 14 (permalink) Old Jun 3rd, 14, 12:18 AM
KeithD
Originally Posted by Coppertop View Post
Why call MAD?
I think that's the whole problem
"You laugh because I am different. I laugh because you are all the same."
Chevello is offline
post #9 of 14 (permalink) Old Jun 3rd, 14, 12:28 AM
moved
post #10 of 14 (permalink) Old Jun 3rd, 14, 12:30 AM
Rocky Hill
My Shift Works amp gauge did the same thing and I switched the two wires on the back of the gauge and it operated properly.
Rocky
A Man And His Chevelle!
It's A Beautiful Thing.
TC Member #1530
rocks66ss is offline
post #11 of 14 (permalink) Old Jun 3rd, 14, 1:11 AM
Originally Posted by chevello View Post
i think that's the whole problem :d
post #12 of 14 (permalink) Old Jun 3rd, 14, 1:26 AM
Rich NYC
There's your problem....
The factory ammeter needs the factory designed wiring layout to provide the proper voltage drop.
The original alternator's output wire ran to the junction of battery wires at the horn relay. The relay's buss acted as the main distribution for power.
The ammeter looks at the potential difference (very small voltage) between the horn relay and the junction block behind the battery (which is connected to battery (+) terminal.
By you moving the alternator output right to the battery + lug, you have upset the balance and therefore it will never work as designed.
As a further note , this are used as rough indicators only. It should stay close centered at zero or slight hair into the + zone. Swings into the discharge zone (battery junction higher voltage than horn relay) and swings into the charge zone (horn relay higher voltage than battery junction) indicate problems as there should not be that great of difference between the two points unless there is a problem or the system is being pushed to its design limits.
It's a catch 22 for most. If you want to take advantage of a higher power alternator for more added on goodies, you need to change/bump up wiring gauges, THEN your factory ammeter does not function properly.
As many know, I am not a fan of 1wire alternators. But that's enough typing for tonight.
post #13 of 14 (permalink) Old Jun 3rd, 14, 10:03 AM
Still should call MAD they will give a better answer + options for you take.
Jon
jonh is offline
post #14 of 14 (permalink) Old Jun 4th, 14, 12:13 PM
Jon
Joe's (Coppertop) answer above is as good an answer as you could expect to get.
USAF Retired (1968-1988)
David Bates is offline
This Thread is more than 2092 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
