TKO NSS Relay - Chevelle Tech
post #1 of 9 (permalink) Old May 27th, 14, 8:38 AM Thread Starter
TKO NSS Relay
So I've been doing a lot of reading about people running a 30 amp relay between the neutral safety switch and starter on their TKO. I've called American Powertrain and TREMEC, and both stated that it is not necessary. Can someone set me straight on this? Thanks.
glide is offline
post #2 of 9 (permalink) Old May 27th, 14, 10:40 AM
Bryan
Re: TKO NSS Relay
I have an older TKO in my 59
The NSS is not wire thru a relay on that car.
It has given me no problems since '05.
However, someone here did have an issue with the NSS on a later trans.
Might have been a fluke---dunno.
At any rate, I wired a relay in my 66 for a couple of reasons.
Insurance as to not overload the switch
It is easily accessible and removed to help prevent the car
being driven off by someone that should not be in it.
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done
On the street now!!!
Bryan59EC is offline
post #3 of 9 (permalink) Old May 27th, 14, 11:27 AM
Ron
Re: TKO NSS Relay
I could not find a rating on the switch and I did try. I found the peak currents to engage the solenoid were in the 25 to 30 amp region and looking at the size of the switch I was suspicious of it taking that much current on a repeated basis over years of service.
Thus I put relays in the circuit that had a 75A peak rating. A little margin is always good.
My car is here:
bikeron is offline
post #4 of 9 (permalink) Old May 27th, 14, 12:49 PM Thread Starter
Re: TKO NSS Relay
I guess it's not that much work to wire in relay anyway. And I like the idea of using it for a kill switch. Thanks for the replies.
glide is offline
post #5 of 9 (permalink) Old May 27th, 14, 12:53 PM Thread Starter
Re: TKO NSS Relay
One more thing... are you just cutting off the connecter on the tailhousing pigtail? Or were you able to find the connecter? I've been looking around, but am having trouble finding one.
glide is offline
post #6 of 9 (permalink) Old May 27th, 14, 1:24 PM
Bryan
Re: TKO NSS Relay
Use two single connectors for an old Ford starter solenoid.
Same connector is used on temp and oil senders as well.
I read somewhere that the posts are not threaded with a regular thread so you cannot use a ring term and a nut----they are just ribbed so they hang onto the connector.
Bryan's toyz
post #7 of 9 (permalink) Old May 27th, 14, 2:09 PM Thread Starter
Re: TKO NSS Relay
You lost me a little bit there. Do you have a link to what you are referring to?
I ended up finding the mating connector for the pigtail AMP Performance, but they wanted $45 plush shipping. Yikes.
http://ampperformance.com/
glide is offline
post #8 of 9 (permalink) Old May 27th, 14, 2:36 PM
Bryan
Re: TKO NSS Relay
order two of these
http://www.cjponyparts.com/90-degree...-1995/p/HW218/
These may even be available at NAPA.
Just a simple Ford repair pigtail.
Used on the starter solenoid, oil pressure, temp, and a similar wire is used for the early Mustangs with foglamps
Bryan's toyz
post #9 of 9 (permalink) Old May 27th, 14, 4:43 PM Thread Starter
Re: TKO NSS Relay
Thanks Bryan!
glide is offline
This Thread is more than 2237 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
