Please Help - Cowl Induction Wiring - Chevelle Tech
post #1 of 4 (permalink) Old May 25th, 14, 9:39 AM Thread Starter
Charlie
I have tried to do the research and just cannot seem to get my cowl induction to work. I had someone originally do the cowl induction setup and he could not complete it in a timely manner so I ended up taking the vehicle back and now I am very confused.
The flapper closes when the vehicle starts but does not function when the accelerator is pressed. i have tried reading pas threads but just cannot get it, It seems like there should be some sort of connection coming from the fuse box to the pedal switch? Im so confused, a video or detailed diagram would be much appreciated.
My apologies in advance, I did try and research this before posting a new thread..
Please help!!!
http://i305.photobucket.com/albums/n...23a-Copy-1.jpg
http://i305.photobucket.com/albums/n...9141823a-1.jpg
http://i305.photobucket.com/albums/n...19141832-1.jpg
http://i305.photobucket.com/albums/n...519141828a.jpg
http://i305.photobucket.com/albums/n...0519141827.jpg
http://i305.photobucket.com/albums/n...519141823a.jpg
electricman98 is offline
post #2 of 4 (permalink) Old May 25th, 14, 9:53 AM
autumngold
Re: Please Help - Cowl Induction Wiring
the cowl induction is tied in with the trans kickdown switch harness from the pedal switch,this is just the inside solenoid,the outside is vacuum operated.fuse box to switch power.you will find pics on this site under kickdown switch wiring.
1970 ls-5 numbers matching
marcrose is offline
post #3 of 4 (permalink) Old May 25th, 14, 9:57 AM Thread Starter
Charlie
Forgot to mention, this is a 1970 Chevelle, if it matters
post #4 of 4 (permalink) Old May 25th, 14, 7:20 PM
Charlie,
The actual flapper is vacuum operated.
The electrical portion operates an inner door to protect the ducting when the car is off (the outer door, of course, will be open due to the lack of vacuum).
The vacuum line that feeds the actual hood mounted "pod" needs to connect to the check valve, and then ultimately to a manifold vacuum source.
https://www.chevelles.com/forums/showthread.php?t=397976
https://www.chevelles.com/forums/showthread.php?t=558098
NOT using the in-line check valve will result in operation like this:
Make sure the vacuum line is not pinched when the hood shuts.
Coppertop is offline
This Thread is more than 1806 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
