65 Alternator - Chevelle Tech
post #1 of 3 (permalink) Old May 23rd, 14, 8:54 PM Thread Starter
wib
65 Alternator
Had a "battery" problem today that I think is alternator related. How difficult is it to replace the original alternator/regulator setup with an alternator with integrated regulator?
wib is offline
post #2 of 3 (permalink) Old May 24th, 14, 2:50 PM
grr
Re: 65 Alternator
I think if you go here it'll answer a few questions - It is about 10 posts below yours.
https://www.chevelles.com/forums/showthread.php?t=616698
There are conflicting points of view on how to do it, but all versions will work..
Here is how I did my original Shelby and 2 other early Mustangs. I went to this site...
http://www.madelectrical.com/
http://www.madelectrical.com/electri...hreewire.shtml
http://www.madelectrical.com/electri...elcoremy.shtml
http://www.madelectrical.com/electri...esensing.shtml
It all made some sense to me and seemed to work just fine...
Just my .02.....Gary
grr456 is offline
post #3 of 3 (permalink) Old May 25th, 14, 9:06 PM
Re: 65 Alternator
Not sure what you mean by a "battery" problem (with the usage of quotes)...
The first thing you should do is get to the root of the problem.
Is it the alternator? Time to check.
You need to measure the voltage at the battery terminals with the engine running. Ideal voltage is between 13.8 volts and 14.2 volts.
Coppertop is offline
This Thread is more than 1911 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
