AAW Classic Kit 65 Question - Chevelle Tech
post #1 of 8 (permalink) Old May 21st, 14, 4:35 PM Thread Starter
Ron
Regarding electric fan wire (orange) on the front light kit.
What exactly does it connect to? It says "to electric fans".
I have a twin Spal fan system. The instructions for this orange wire , from the relays, says " connect to ignition switch+vdc when engine is in run position".
I'm not sure where that is.
I'm just not getting it. Can someone explain this to me please?
Thanks, Ron
Ron 65SS (Mine since 1976) -327C.I.-Autogear Muncie-Strange S60-
Dyno video & first test drive
327 by Wolfplace(429 H.P)
Paint and body
engine build thread
65 SS is offline
post #2 of 8 (permalink) Old May 21st, 14, 5:26 PM
grr
Re: AAW Classic Kit 65 Question
"connect to ignition switch+vdc when engine is in run position"
I assume this is either a literal translation from another language, or someone wants to be very wordy.
I think they are just saying to connect to a switched 12v source. VDC = Volts Direct Current...+ = positive side of battery...
Just my .02.....Gary
grr456 is offline
post #3 of 8 (permalink) Old May 21st, 14, 5:51 PM
Ron
The orange wire goes to supply the power to run the relay coils (not the fan power). The contacts in the relays, in turn, supply power to the fans.
The AAW guy, Donny, and I had a discussion about this.
https://www.chevelles.com/forums/show...145&highlight=
Look down the thread a bit..at posts 2 and 9.
My car is here:
bikeron is offline
post #4 of 8 (permalink) Old May 21st, 14, 7:39 PM Thread Starter
Ron
So the orange wire from the AAW front light kit, that says "to electric fan", connects to the wire from my Spal fan relay? Is this my 12 volt ignition source for the relay? I think I understand.
Paint and body
engine build thread
65 SS is offline
post #5 of 8 (permalink) Old May 21st, 14, 7:51 PM
Donny
Not sure where you're reading this, and I write the instructions. LOL
Yes, That orange wire is the 12 volt ignition feed that should be used to trigger your fan relay.
Donny
aawtech is offline
post #6 of 8 (permalink) Old May 21st, 14, 7:52 PM
Donny
Is this perhaps on the SPAL fan relay instructions?
Donny
aawtech is offline
post #7 of 8 (permalink) Old May 21st, 14, 8:31 PM Thread Starter
Ron
Thanks Donny and Bikeron
Yes, that was in the relay instructions.
Paint and body
engine build thread
65 SS is offline
post #8 of 8 (permalink) Old May 21st, 14, 9:22 PM
Donny
Ok, that's why it didn't ring a bell. Thought I was going batty.
Donny
aawtech is offline
This Thread is more than 2138 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
