7" round light emitting diode headlight: Peterson "701C Piranha LED" - Chevelle Tech
post #1 of 5 (permalink) Old May 21st, 14, 3:02 PM Thread Starter
Drop-in. (Form factor matches standard 2D1 configuration, w/ H4 electrical connection) $181.79 at RockAuto. Weighs 19.7 oz. Flat clear face. Makes white light. Bottom half completely dark on low beam. Well defined upper cut-off on low beam aids adjustment. High beam really lights up the signs. 9-32 volt operating range (no dimming like my halogens at idle)
Compliance: DOT/FMVSS108, SAE (says "DOT SAE HL 12" on lens)
Compatability: SAE Type 2D1, Par56, H6014, H5024, H6024
"American Made"
www.pmlights.com
dogsridewith is offline
post #2 of 5 (permalink) Old May 21st, 14, 4:08 PM
Jerry
Re: 7" round light emitting diode headlight: Peterson "701C Piranha LE
Did you use the anti-flicker harness with the lights?
Jerry Briggs
ROLL TIDE!
Jerry Briggs is offline
post #3 of 5 (permalink) Old May 21st, 14, 4:23 PM
Ron
Not a lot of info but they draw less current than the halogens or the std incandescent. This would make headlamp and dimmer switches last longer.
My car is here:
bikeron is offline
post #4 of 5 (permalink) Old May 21st, 14, 5:14 PM Thread Starter
what's that?
post #5 of 5 (permalink) Old May 21st, 14, 11:02 PM
Jeep Only
701-491
Anti-Flicker Harness For LED Headlights
Anti-flicker harness plug for 701C series LED headlights.
Used on Jeeps 2007 and newer.
ACES #00140
TEAM CHEVELLE #0038
rick is offline
This Thread is more than 2150 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
