Need help identifying this connector - Chevelle Tech
post #1 of 3 (permalink) Old May 21st, 14, 10:26 AM Thread Starter
Hello,
I'm wrapping up my dash/gauge swap and can't figure out what this connection is or where it went. Its located on the drivers side and is separate from main dash harness, hooking directly into the ACC plug on the fuse panel. I have looked through my wiring diagrams and searched, but no luck. Can anyone help?
Name:	Chevelle connector.JPG
modscott is offline
post #2 of 3 (permalink) Old May 21st, 14, 11:55 AM
Re: Need help identifying this connector
That goes to a rear window defogger switch that should be mounted to the right of your steering column. It is a separate harness, due to that it was an optional item. Does the dash have that switch? Do you have a rear window defogger for the car?
RealRed70 is offline
post #3 of 3 (permalink) Old May 21st, 14, 12:16 PM Thread Starter
Thanks a lot for your help! The original dash did have the defogger switch, but someone removed the rear assembly long ago. I kept the switch, but don't have any of the other parts.
modscott is offline
This Thread is more than 2208 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
