Reproduction Tach and HEI Distributor - Page 2 - Chevelle Tech
post #16 of 21 (permalink) Old May 22nd, 14, 8:53 PM
Re: Reproduction Tach and HEI Distributor
Fit the tach, using jumper wires, to another vehicle, and see if it works.
Dave Ray is offline
post #17 of 21 (permalink) Old May 23rd, 14, 5:11 PM Thread Starter
Brandon
Got my tach out of the dash and hooked up to a tester. It was indeed bad. Got it switched out for a new one, that was tested and works. Let's try this again...
blmwake is offline
post #18 of 21 (permalink) Old May 24th, 14, 1:13 AM
Great you found the issue, bad it was a new defective unit. It does happen, a lot more than most think it does.
Dave Ray is offline
post #19 of 21 (permalink) Old May 24th, 14, 5:32 PM Thread Starter
Brandon
Yes, bad it was a defective unit and bad that I had to pull the dash to fix it. We were probably 3 weeks from finishing the restoration. Just a slight delay but should be back on track next week. Thanks everyone for the help!
blmwake is offline
post #20 of 21 (permalink) Old May 25th, 14, 9:02 PM
...and reproduction parts strike again....wow.
Sorry to hear of your misfortune.
Glad you were able to get to the bottom of the problem.
Coppertop is offline
post #21 of 21 (permalink) Old May 25th, 14, 9:56 PM
Allan
I bought the corvette filter on ebay, my jumpy eratic tach would not work at all with it.
after it removed it I cleaned up he routing of my tach wire and draped it over the spark plug bracket, so it is not near any other wires or metal
now it works fine/
I have a 66 SS with Accell HEI and old vintage sun pro tach
al1950 is offline
This Thread is more than 2146 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
